What kind of single coil
Started by Peterku, April 01, 2006, 08:14:26 PM
Peterku
Hello,
What kind of Strat neck single would provide the most balanced (= not overly bassy or nasal) sound when in parallel with a hot Alnico V humbucker like the Nailbomb (in series, not split)?
Would a low-output or a hotter single coil be the best for the task?
Have a nailbomb with irish tours......series/parallel and single.....sound great together
I have  a pair of Trilogy Suites with my Nailbomb - they balance great in split and combination sounds.  That said, I am going to be moving the NB to a different guitar and using it in a HSH set with a Nailbomb neck and an Irish Tour in the middle!
Quote from: PhilKingI am going to be moving the NB to a different guitar and using it in a HSH set with a Nailbomb neck and an Irish Tour in the middle!
And a FLOYD ROSE!!!!!!!!!!!!!!!  :!:  :!:  :!:  :roll:
Peterku
Tim
The Trilogy Suite, despite being a high gainer on paper, always surprises by how genuinely Straty it can be and will work really well in parallel.
Tim
Peterku
Thanks for your response, Tim.
I use 11' strings. Won't a (relatively) high-output Alnico V single coil wound with a thinner wire be too bassy in the neck position?
