Author Topic: Pickup wiring  (Read 3310 times)
shamahockey
Pickup wiring
« on: July 14, 2016, 11:32:19 AM »
I'm looking at buying a Juggernaut bridge and either Emerald or Coldsweat neck to go into a schecter 7 string with a mahogany body, maple neck and ebony fingerboard.
I want to wire up a 3 position switch so that position 2 is one coil from the bridge and one from the bridge and hum canceling.  From my reading this is how Petrucci wires his pickups?  I have 2 volumes, 1 tone and a 3 way blade switch.
1 - Do I need to request that the neck pickup have it's polarity reversed?
2 - Is the middle position of the switch supposed to be wired in parallel or series to be hum canceling?
3 - Does it matter which one of the coils is used from each pickup for the middle position?
4 - Can someone refer me to a schematic for this wiring?
For reference I've searched thru the boards and talked to BK previous to this but am still a little confused...
Any advice would be appreciated.
Troy Baer
  • BKPs: Emerald and Emerald-7 sets
Re: Pickup wiring
« Reply #1 on: July 14, 2016, 02:56:02 PM »
The Petrucci style wiring is here:
http://www.dimarzio.com/sites/default/files/diagrams/2h1v1t_1ep1111petrucciDsonic.pdf
It requires a 4PDT switch.  I'm not sure how you would modify it for 2 volumes, though.
The middle position should be hum cancelling.  It's the two inner coils in parallel (though Petrucci has repeatedly referred to it as "series" in interviews for some reason).
"Cannot run out of time!  There is infinite time.  You are finite, Zathras is finite, this... is wrong tool.  No, not good, no, never use this." --Zathras
shamahockey
Re: Pickup wiring
« Reply #2 on: July 14, 2016, 09:22:25 PM »
Thank you for the reply!
Are the 2 inner coils the magnet or the slug in this scenario? And is this assuming I've requested a reverse polarity neck pickup?
Troy Baer
Re: Pickup wiring
« Reply #3 on: July 14, 2016, 10:37:18 PM »
The inner coils are usually the slug coils (or the blade coil in the case of the Crunchlab).
I could be wrong, but I don't think this requires a reverse-polarity neck PU.  I've done the Petrucci wiring on a couple different guitars (an ESP H207 with a Dimarzio Air Norton-7 in the neck and a Duncan Custom-7 in the bridge, and an OLP Petrucci with the stock pickups) and never had to do a mag flip or anything like that.
« Last Edit: July 15, 2016, 09:22:03 PM by Troy Baer »
