CS vs C-Bomb (bridge) Just Looking for simple useful description
Started by jase2677, August 01, 2016, 08:21:32 PM
jase2677
CS vs C-Bomb (bridge) Just Looking for simple useful description Of similarities & differences between the 2. Especially for clean & metal distortion. Thanks
Lucas
Well, it depends what you`re looking for. Also what guitar you`re going to put them into, cuz that makes huge difference.
I can only say about CBomb. I have one in dark sounding all mahogany Dean Cadillac.
It surprisingly has a really good cleans for ceramic pickup. I would rather call it rhythm pickup rather than lead pickup. Also when it comes to distorted sounds, it is not precise enough for complex riffing. I becomes little blurry. Great for rock, hard rock and metal, but not for complex technical metal. It is really aggressive.
I sounds great with overdrive as well for classic rock/rock, it gives a little bit of aggression and modern edge, but what`s what I love about that pickup.
I've had the Cold Sweat and A-Bomb in the same guitar.  Not the same but close enough to comment.
A-bomb was a lot more hairy and aggressive sounding, a very '90s pickup like Sepultura or Machine Head
The Cold Sweat is much smoother and has an '80s sound and feel with a nice tight bottom end with just enough bottom-end thump for '80s thrash.
Both pickups can be quite bright
I hope this helps.
#3
Well, in my 73 lp custom, the cold sweat was a lot brighter and more articulate
The c-bomb was darker, quite compressed for bkp standards, but a lot more balanced and forgiving, with an overall smoother response
It actually felt less aggressive than the alnico nailbomb in the same guitar, despite of it being hotter
Both have a lot of bass and treble, but the cold sweat has some midscoop, while the c-bomb has a flatter midrange
The c-bomb is Said to be an overwound cold sweat, which makes sense, considering both the similarities and the differences
I thought that the C-Bomb was basically the same wire etc as an A-Bomb but with the ceramic magnet used in the Cold Sweat
Quote from: Agent Orange on August 03, 2016, 08:16:46 AM
Well, it is
Nailbombs have fuller bobbins, but the same wire type, gauge and coil mismatch
JimmyMoorby
CS and Cbomb are fairly similar not had them in the same guitar but the biggest difference is in the mids as Eric said.
The nailbomb mids and balanced a fair amount of hi, central and low mids very balanced whereas the cold sweat has hi mids and less lower mids etc.  The nailbomb is higher output and more compressed too.
Cold sweat a lot more versatile IMO same goes for the alnico nailbomb in this instance putting a ceramic magnet in the nailbomb makes a big difference.
jase2677
Background;
Have a cs matched pair in an Ibanez s w mahogany body. This was a muddy b*tch until the cs's were installed...now it's rad as all hell. I find it's gritty with high mids and just enough bass to excel at clean and metal distortion tones I seek.
Now, have my 1st guitar which is an Ibanez Rg w a basswood body. Had seymour distortions, 81's, B&B xl500l's, l500r's  & now have l500l's which I like the best, the l500l are pretty even response without having "too much" output that they sound cluttered or anything. I think dimebag probably used the l and not the xl which came later to go up and beyond the l and was renamed xl, but who knows. To get the l to shine bass has to be dropped, the mids have to be increased, treble and presence set lower, and volume decreased in the same modeler patch for it to be useable when switching to the l from the cs.
So, I like my cs's the most and figured why not get 2 guitar's in the same satisfied with tone league. So figured maybe a c-bomb to be similar, bit a little different. The l is a little more murky than my cs's and want to get rid of that aspect. I also thought of ordering a custom holydiver set with a ceramic bridge magnet, like a c-hd set, but this is where I am at.
Well, you can't have a ceramic holy diver, but a painkiller should get you close to that
The miracle man works really well in basswood, by the way
Quote from: jase2677 on August 03, 2016, 09:38:05 PM
I would go with the Miracle Man here for the bridge and maybe a Holy Diver neck
JimmyMoorby
If you want a 'tighter holy' diver that describes the juggernauts and for a bridge they have the best cleans I've ever heard.
jase2677
Find alnico gives fuller mids, where a ceramic cuts the mids somewhere and dips them a bit depending on the model, my 500l is alnico and it has fuller mids. Just puts me off a bit. Thought could order a ceramic hd? My cs has upper mids that I like and the lower mids are cut a bit. The miracle man sounds like it flops mid dominace from what like about cs. That's why thought about c-bomb. I also hate mid pickups. Have them almost always wored in parallel at the neck, but they are too opposite of thin for me. I would like my neck pickup better if it is similar to bridge. Have not tried the inline cap mod yet in the neck, but would like to with neck still in parallel.
JimmyMoorby
Maybe think of the c-bomb as a more powerful cold sweat in terms of output and tone.  I've been told by BKP the c-bomb is the best 'half way house' between a cold sweat and a miracle man.
Is that what you want?
The c-bomb is definitely more for aggressive metal styles whereas the alnico version warms the top end and adds some hi mids. I have found the alnico nailbomb to be the most versatile pickup I've ever come across (In alder super strats at least) from hard rock to extreme metal whereas the c-bomb could be extremely versatile across all metal sub-genres if that makes sense.
A BKP user is likely to tell you the alnico nailbomb is extremely middy although compared to all the other brands it isn't at all.  The alnico nailbomb has lots of hi mids but it's nicely balanced out with a 'warm treble'.  Some people bash it on here but BKP describe it as one of their most organic and versatile pickups and I couldn't agree more.
The nailbomb divides people on here.... each to their own.  Some people say it's for thrash and beyond but I do Van Halen covers with it and only get compliments on my tone and doing service to the songs.  These are strangers at gig and they don't have to tell me these things....
I was actually disappointed with the alnico nailbomb cause it wasn't nearly as middy as I expected
It is middier than the CS or MM but no near as middy as a holy diver, black dog, or even a riff raff
The c-bomb had a flatter response, but wasn't scooped at all
A ceramic powered holy diver would make a painkiller, by the way
Yellowjacket
I have an A-Bomb and I really like it in my Gibson Les Paul Standard.  I have it paired with a Rebel Yell in the neck and it gives me lots of great tones through my Mesa Boogie Electra Dyne.
I find that as a player, I like to match guitars and pickups with amplifiers.  My Juggernaut equipped super strat works with my Electra Dyne and my 2 Channel Dual Rectifier whereas the mahogany Godin LG works best with the Dual Rectifier.  It has a VHII neck and a Rebel Yell bridge.
The Les Paul sounds decently good with the Dual Rectifier but it really stands out with the Electra Dyne.  The A-Bomb has just enough push to drive the amp hard and it is organic and ill tempered to goad some raunchy and awesome tones from that amp.
