Can anyone tell me how to wire up the following (with the toggle set up to change between coils wired in series or parallel)?
Nailbomb neck pickup (4 conductor) -> DPDT mini toggle -> neck volume pot -> selector switch -> output jack.
The other pickup will be wired like this:
Nailbomb bridge pickup (4 conductor) -> bridge volume pot -> selector switch -> output jack.
What are the little jumpers between switch positions that I see in diagrams of push-pulls?
This is just a little toggle like the following:
https://www.jaycar.com.au/dpdt-standard-toggle-switch/p/ST0572I have moved the Switchcraft selector switch to what was previously the neck volume position and the two volume pots will be placed in the other two holes, eliminating the tone control. The DPDT toggle will go where the selector switch used to be, on the pickguard.
