Author Topic: Help needed in choosing pickups  (Read 3398 times)
Gilad Bronshtein
« on: February 04, 2017, 02:51:32 PM »
(First post in the forum!)
Hey guys!
I need help in choosing my new pickups because my current ones (stock pickups) are starting to sound a little bit strange...
I have a PRS S2 Custom 24 and if it matters (I truly know nothing in pickups) I have 10-52 strings.
I play mostly progressive rock and progressive metal, some fusion here and there and rarely technical metal and metal core.
As of for the sounds I am looking for here are the descriptions:
Both pickups must be clear even in distorted sounds (as much as possible of course).
For the neck: a warm sound. I usually play clean on this pickup (sometimes I split it) and fat leads. I want this pickup to have a bite but not too much.
For the bridge: here is the most problematic thing - I want it to be dominant in the low and mostly in the mid frequencies and not so much on the high frequencies, but enough high frequencies that will satisfy. For sound references I really love how Rabea Massaad and Guthrie Govan sound, I truly love their sound I would like to achieve it, at least pickup wise..
Thanks for the help!
Gilad Bronshtein.
  • Random Solution
Re: Help needed in choosing pickups
« Reply #1 on: February 04, 2017, 04:09:19 PM »
I've owned a few PRS Custom 24 guitars, albeit only the SE versions and I've tried a few pickup variations. My favourite all-rounder was probably the Crawler. Its natural home is Blues Rock but it will cover anything up to early 80s Metal without difficulty. It's often described as a 'dark' pickup but that's a little misleading. It does certainly have a strong bottom end but the misleading impression of darkness is because the mids in this pickup are focused more on the low mids, making the pickup sound huge. You get some really fat and sweet leads from a Crawler. The tone is very rich and has an incredible growl to it. Of all the pickups I'd suggest for you, this one is the softest in the bass under gain but it's not mushy by any means at all because by the time it starts to give up, you're into fairly serious levels of gain and against that, it has the best overall tone, the best leads, the best cleans and the best splits. Honestly, this is an astonishing pickup in a PRS.
Another fantastic bridge option for a PRS Custom 24 would be an Abraxas. It uses the same wire as the Crawler but uses an AIV magnet instead of AV. This would normally suggest a softer bass response but the lighter wind means it isn't as dark overall and that little bit of extra brightness helps to keep things very articulate. Don't be fooled by the name, the Abraxas will do your progressive Rock and Metal all day long and offer tremendous versatility. Superb tone, great cleans and sweet leads make it a very attractive proposition. This pickup is certainly related to the Crawler, it's just dialled back a bit so not as dark and growly.
The next option would be the obvious one, which is the Holydiver. This one is clearly aimed at that 80s Metal tone but because it uses 44AWG wire instead of 43AWG, it actually ends up sounding a bit more modern than it should so if anything, the Abraxas has a more authentically 80s Metal tone. The plus side is that has stong mids across the board, great leads and remarkably good tone for a contemporary pickup. It's the tightest of these three. Some people can say the prominent mids make it sound a bit honky in a PRS but I always found it absolutely fine.
For the neck pickup, for me at least, it's a straight choice between a Holydiver and an Emerald. Surprisingly, the Emerald is the hotter and more modern sounding of the two. Both are awesome but based on your description, I'd say you want an Emerald as it ticks all of your boxes. Essentially, what you described IS an Emerald.
There are some good reviews of all of these in the Review sticky and if you need any more information, just let me know.
