New wiring for Les Paul
Started by callan, July 21, 2017, 12:50:40 AM
callan
I'm thinking of replacing the wiring on my Les Paul since I put a set of Mules in it recently.
I was just looking at push-pull pots first to get the split sounds, but I might just replace it all.
Has anybody else done this, can you recommend any sets?
I found this one, but not sure how it rates, or if it's even an upgrade on what I have today.
Thoughts?
richard
Splits on a set of Mules would be VERY low output, way lower than a standard Strat pickup. Not very usable I would think.
PRS S2 Singlecut RY's
JV Strat  IT Bridge
Gibson SG JB bridge
Fender Bassbreaker 15
Yamaha THR 100 Dual
Quilter Aviator Cub
Yellowjacket
Why not try series / parallel with the push pull wiring?
The parallel wiring is close to a P90.  I think it would be a very usable and appropriate mod.
timmy_pix
I had splits on my Mules in my old Epiphone (now stolen) and they were super usable. Sounded almost Tele-ish in the middle position. I cannot praise those pickups enough.
BKPs owned:
Stormy Mondays, Mules, Emeralds, 10ths, Mothers Milks, Nantucket, Black Dogs, Holydivers, A-bombs, Warpigs, Sinners, Cold Sweats
JoeHenry
Just done exactly this on a LP - previously on a PRS SE245. Hopefully, you'll get this before making the same mistakes as I did. For ref I was an electronics engineer many moons ago - so no stranger at all to soldering etc.
However -
The Alpha switching pots are fiddy little buggers - very little space to solder on the tags on these things. CTS make a pot with a much easier access switch - two big lugs on the bottom. All you are doing when you split the coils is shorting the middle wires to ground (earth) when you pull the switch up. So you really only need two poles. I used these pots on the SE245 and it was no problem - apart from having to file the holes on the top out a bit for the thicker shaft - again quite easy with a round wood file.
Another issue with the Alpha switches is that they are very flimsy - I was tightening the nut on the top of the pot shaft and was inadvertently twisting the whole thing on the other side - the wires are fixed of course and the twisting action pulling on the wires actually pulled the switch section apart without me noticing it. I even tried to rebuild the switch - it's a simple mechanism but very small and too fiddly to fix. So - always brace the dam thing on the other side when you tighten the pot nuts on top.
So that was the SE245. Wise to these issues - I bought CTS pots with the big robust switch on the bottom for the Les Paul. Mine has the ground plate inside the cavity which I retained. However - the CTS pots were billed as 'medium shaft length which I thought would be long enough to go through the plate and the maple cap. Guess what - it wasn't. It wouldn't even go through the cap on its own without the plate. Stung again (£12 each the b'tards) - I had to then buy long shaft Alpha pots (complete with the shitety little switch).
Much swearing and fiddling later - I got the thing installed and it works fine in terms of splitting the coils - but I have to say - and its the subject of a different post - I wish I hadn't bothered because the abraxas set that sounded good in the SE245 is pretty poor in my LP - I am going to end up taking all of that cr@p out and putting the original pups back in.
You might have a different taste/experience - but mechanically, watch out for those flimsy switching Alpha pots. Check the depth of your maple cap on your LP and if you can get away with the CTS ones - go for those - much better.
JoeHenry
Just looked at the date - probably too late  :grin:
It was top of the list and I just assumed!
