Author Topic: midi  (Read 3472 times)
Jonesy
    • http://www.myspace.com/rory_boy
midi
« on: April 08, 2006, 11:30:21 PM »
whats the deal with midi...is it the best wy of creating patches if you use multiple stomp boxes?
Also, do you need a midi compatible amp?
Nailbomb - Mississippi Queen - Mothers milk
ibanez4life SZ
    • http://thatguitarkid.dmusic.com/
midi
« Reply #1 on: April 08, 2006, 11:45:27 PM »
Yes, from what I know, the amp does have to be midi compatable!
And once you obtain multiple stomp boxes that need to be changed on and off, midi is the way to go, unless if you want to be dancing on stage. In some situations, the switching is impossible without it!
Ibanez SZ520
Mesa Dual Recto
Avatar 412
Morley Tremonti Wah
Keeley SD-1    FOR SALE!!!
ISP Gate
lepersmeesa
midi
« Reply #2 on: April 09, 2006, 12:52:16 AM »
It is possible to switch a non midi amp using a midi board. The pedal it self has to have the same kind of inputs ( most amps have jacks which switch the channels ). You can save these as patches ( on or off on the jack ) while also switching midi controlled effects etc.
I am Ted Theodore Logan...
www.myspace.com/thesafetyfire
midi
« Reply #3 on: April 09, 2006, 03:40:53 AM »
You would need more than just a MIDI controller to do any kind of intricate switching; you will need a controller (I use a Roland FC-200), as well as a MIDI-controllable switcher, and probably a looper as well.
Not all switchers are created equally, though -- some are not instantaneous.
This kind of rig can also be very expensive. My foot controller cost $400 alone.
ibanez4life SZ
midi
« Reply #4 on: April 09, 2006, 06:12:08 AM »
Definitely really expensive......but worth it if you're serious about your tone and easy contolling for serious gigging.
Ibanez SZ520
Mesa Dual Recto
Avatar 412
Morley Tremonti Wah
ISP Gate
