November 20, 2026, 10:40:13 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
complete wiring
complete wiring
Started by maliciousteve, April 11, 2006, 01:41:11 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
maliciousteve
Guest
Logged
complete wiring
Could someone help me out with wiring a guitar for a 1 volume pot, 1 humbucker set up? I'm getting sound out of my guitar but all i get is quite a bit of buzzing and the sound is weak. I'm using a Dimarzio X2N by the way.
Middleweight
Logged
complete wiring
#1
April 11, 2006, 02:35:29 PM
this might be the right diagram for you
http://www.guitarelectronics.com/product/WDUH0101
HOWEVER, if you have a logarithmic/audio pot you have to swap left and middle pin on the poti.
Which type of poti are you using, 500 or 250 KOhm?
The buzzing/thin sound might come from a wrong wring, maybe you only hear one coil of the HB ...?
Middleweight
London & Southeast's Number 1 BKP stockist
Logged
complete wiring
#2
April 11, 2006, 11:55:44 PM
Yes - do check that you have the Dimarzio wiring scheme sussed as it is different to the BKP one
Red = hot wire to pot or switch
green = earth (along with bare wire) which are soldered to back of pot
white and black are soldered together and isolated (heatshrink or tape) - can be used as a coiltap to a switch to turn off one coil
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
complete wiring
User actions
Print
