Pickups for Gibson LP standard - tight metal
Started by evenfell, December 07, 2017, 12:43:08 PM
evenfell
Hey
I am thinking of changing pups in my new Gibson LP standard 2011
It came with Burstbucker pro, but they are to weak and not articulate enough
I have tried to read about what I want, but cant really find it.
So I hope you guys can help.
I usually play through a JVM 410 or a Mesa Dual rec boosted with a treble booster
What I want is:
Bridge: Low growl, popping harmonics and drumlike rhytm licks.
I tried my friends Duncan dimebucker in an SG, and thats pretty much nailed the tone I am after, but its to trebly
So do bareknuckle have anything like this with more growl and deep rhytm when needed
Miracle man?
Neck:
Open for suggestions here. I want this one to have leads like slash or similar.
Stormy MondaY?
Thanks
Sounds more like alnico Nailbomb, perhaps paired with a Emerald-neck. But I would inspect the modern Juggernaut-bridge too.
capac
I'd go with something ceramic in the bridge...
Aftermath (bridge), alnico Black hawk (set), holydiver (set)
Yellowjacket
Quote from: evenfell on December 07, 2017, 12:43:08 PM
Hey
What I want is:
Miracle man?
Neck:
Stormy MondaY?
Thanks
Smooth treble and growly, thick mids and low mids?  Tight?  Try a Juggernaut bridge.
What is your tuning / string weight?
The Alnico Nailbomb is great but I'm not sure if it will sound as phat as you want.  The A-Bomb is more balanced and it has warm highs.
capac
evenfell
Quote from: Yellowjacket on December 08, 2017, 04:02:13 PM
Hey
What I want is:
Miracle man?
Neck:
Stormy MondaY?
Thanks
Thanks for the answer.
I usually have daddario strings 10-52 in E tuning. Sometimes drop D
Ill check juggernaut
evenfell
Quote from: capac on December 08, 2017, 09:15:50 PM
MIracle man maybe?
I was thinking of that, but is it comparable to EMG81? or more deep/growl when needed?
Cause I dont like EMG at all, to sterile
To me the Miracle Man doesn't sound like an EMG at all.
Another pickup you could consider is the Cold Sweat but the Miracle Man has more bottom end
