Author Topic: Humbucker For A Strat  (Read 3169 times)
darrenw5094
« on: February 09, 2018, 12:36:31 PM »
I have a US Strat Deluxe with the 5 way switch and 3 single coils fitted as standard. The pups are David Allen Voodoo Blues set. The bridge is hotter than normal, because it is usually thin sounding in Strats.
Was looking to fit a black coiled humbucker in the bridge to give it more juice, but I don't want it to sound like a completely different guitar when I select the bridge pup. I am thinking the Alnico II buckers, either the PG Blues or the Stormy Monday.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Re: Humbucker For A Strat
« Reply #1 on: February 10, 2018, 01:03:19 PM »
If you dont need a splitted bridgesound, those will do fine, if quite bright in a alder or ash strat, but apparently that's what you're looking for.
darrenw5094
« Reply #2 on: February 10, 2018, 03:35:05 PM »
Thanks. I'm not looking for a split coil sound from it, Just a bit more juice than the single coil. I probably could tame the high end with the tone control
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
