Author Topic: Charvel HS HT Holydiver Cobra  (Read 4401 times)
Dave Simpson
« on: March 10, 2018, 07:23:32 AM »
I have a Charvel with a humbucker bridge and a single coil neck route and was going to try a Holydiver in the bridge and a Cobra in the neck. Is a 500k volume pot going to work with the Cobra?
BKP's: Nailbomb, Miracle Man, Cold Sweat, Mother's Milk, Mule, Rebel Yell, Crawler
stratguy23
Re: Charvel HS HT Holydiver Cobra
« Reply #1 on: March 10, 2018, 08:35:11 PM »
Yes it will work. The higher the volume pot value, the brighter the tone. Since it is a very hot pickup in the neck, it should sound fine. If it is too bright for your taste, you can run a resistor in parallel to have 250kfor the Cobra. When I wired up a Super Strat with a Holy Diver in the bridge and an Irish Tour in the neck, I just used a 500k pot for both, and the Irish Tour sounds good with the 500k volume pot.
« Reply #2 on: March 11, 2018, 12:24:07 AM »
In my HSS-strat I run my Crawler with 500k and the Irish Tours with 250k. For me that works best.
Dave Simpson
« Reply #3 on: March 11, 2018, 07:01:44 AM »
Thanks for the replies. I'll try it out and keep in mind the parallel resistor option.
