Author Topic: Searching for replacement for Juggs on swamp ash guitar  (Read 11072 times)
expiated
« on: May 13, 2018, 05:14:08 PM »
Hi everyone!
Not so long I got my brand new just made customshop guitar with the next specs:
 - 5 pieces bolt-on neck maple / wenge
 - macassar fretboard
 - scale 27"
 - swamp ash body with poplar burl top
 - BKP Juggernaut set
As you can see - quite ordinary specifications :)
I'm in love with BKP PUps, but my experiment has been unsuccessful this time.
Juggs with swamp ash and other stuff gave a quite muddy sound with slightly soaped structure of distortion.
Could anyone please propose me what would be the best replacement for juggs here?
I'm oriented to modern metal sound like Periphery and in my case I'd like to get more open and bright sound.
An finally I'd like to get rid of any mud.
I had a few made of mahogany guitars with Aftermaths but I can't imagine how would it sound on swamp ash.
« Last Edit: May 13, 2018, 05:22:23 PM by expiated »
Re: Searching for replacement for Juggs on swamp ash guitar
« Reply #1 on: May 14, 2018, 01:23:20 AM »
I've read that the Aftermaths don't sound great in swamp ash
I would tend to recommend the Impulse set or maybe the alnico Black Hawk set.
one
  • Nailbomb, Cold Sweat, Warpig, Juggernauts
« Reply #2 on: May 15, 2018, 08:37:56 AM »
Yeah, Impulses or Warpigs. I have the same guitar as you (except for the top, mine is not a FT) with Juggs and I like them a lot anyway. Or maybe the Rags?
« Reply #3 on: May 15, 2018, 10:24:06 AM »
The Warpigs don't sound that 'modern' to me but Ragnaroks, sure
one
« Reply #4 on: May 16, 2018, 08:39:46 AM »
^I use them in my modern death metal band with a 5153 and they kill
« Reply #5 on: May 16, 2018, 09:29:50 AM »
A-Pig??
Nolly
  • Global Moderator
« Reply #6 on: May 16, 2018, 04:38:17 PM »
If you want to stay in the higher output range, Ragnaroks would give you a leaner low end/low mid, but it's definitely going to give make for a midrangey combination - I like that but YMMV. I'd stay well away from Warpigs if you find the Juggernauts to be muddy and lacking brightness.
Personally, I'd strongly urge you to look at lower output options such as the Black Dog, which has a naturally tight and clear sound with plenty of midrange grind, plus the more open character from not being too heavy a wind. I think it'd be a fantastic choice for your application, especially given your thoughts on the Juggernauts.
You could even consider a Riff Raff, which is brighter and more open again. Don't worry, neither the Black Dog nor Riff Raff will sound weak or "vintage" in your guitar.
one
« Reply #8 on: May 19, 2018, 11:12:10 PM »
true grit?
expiated
« Reply #9 on: May 29, 2018, 05:11:52 PM »
Guys, thank you so much for the response
Nolly, there is always a chance that pickups aren't guilty in my problem...
And it would be a tragedy for me. Replace the pickups is much simplier than replace the guitar  :blank:
Firstly I thought to install Nailbomb + VHII set as it is meet quite often on Skervesen with similar specs.
The second candidate was a Miracle Man set - this set I've seen on Skervesens too.
Now I try to find samples of all suggested pickups but I'm already scared that the deal is in my guitar, not in pickups.
« Reply #10 on: May 30, 2018, 04:08:47 AM »
I still think the Impulse set might be your best bet.  It has a bit less output than the others you've considered though.
An alternative would the the Black Hawk (maybe still with the Impulse neck) if you want more output but it might be overpowering somewhere with your woods.  I think though that in general the blade pickups seem to be less fussy about woods etc
Output wise the Impulses seem to be close to the Juggernauts though
This video compares them (in am LTD H-1000).
https://www.youtube.com/watch?v=x5TL4WVdU30
« Last Edit: May 30, 2018, 08:36:11 AM by Dave Sloven »
one
« Reply #11 on: May 30, 2018, 08:18:07 AM »
Nailbombs? you're going to worsen the problem
« Reply #12 on: May 31, 2018, 09:39:59 AM »
I'm with Nolly here. Black Dogs or maybe even Emeralds (could be not tight enough for you). Personally I like lower output pickups > highgain amps. You might not expect it, but even Mules can shred. I believe Nolly did a track with Mules.
expiated
« Reply #13 on: May 31, 2018, 02:38:49 PM »
It appropriates to my taste - pickups with mid output are more preferable for me in hi-gain sound.
I think I must try black dog set. So, the only thing is left - to order the new set of pickups.
Thanks to all once again  :cheesy:
