Author Topic: Two New Builds - Feedback on Pup Choices Please  (Read 4826 times)
Cookie Monster
« on: July 22, 2018, 12:50:28 AM »
Having two Kiesels built soon. Both identical Aries (bolt on) models. They will be alder body, maple neck, fixed bridge. The pickup configuration will be HSS. Controls will be one volume, one 5-way switch, no tone. Style/sounds will be mostly metal, ranging from classic to a more modern sound as well. Of course the hum will be my primary, and I'll use the middle and neck singles both individually, and also in some combination for a variety of clean and distorted sounds.
As for the Hum, after carefully listening to Tim's Modern Metal clips repeatedly, and meticulously cross-comparing every pickup that has them, I'm torn between the Holy Diver and the Nailbomb Alnico. Both are clearly just killer pups. I realize they are also quite different in tone, and I would imagine feel as well. The NB has lowered mids, while the HD has thicker/raised mids. I tend to prefer thicker more prominent mids, which on the surface I think screams HD, yet the qualities I hear in the NB make me want to try one of them as well. All that being said, I think I'll need to get one of each, and actually play these guitars back to back to make the final decision. Are there any from the Vintage Hot line I should also be considering, even though I've got no Modern Metal clips do go by and compare with except for the Black Dog? Speaking of which, would the Black Dog be top dog out of the Vintage Hot line for metal?
As for the singles, I'll need something high-output, which for me means either the Sinner or the Trilogy Suite. And since I'll need the best cleans between the two, to me that then points to the Trilogy.
Does all this sound about right?
Update since my OP:
After having added the Black Dog to the comparison, thanks to Tim doing a Modern Metal clip of it. I think I'm leaning on dropping the Nailbomb, and replacing it with the Black Dog to go along with the Holy Diver for the other guitar. The very present and clear mids, articulation, and I imagine the more open dynamics, yet aggressive nature of the Black Dog are what's attracting me to it.
« Last Edit: July 22, 2018, 02:22:38 AM by Cookie Monster »
Cookie Monster
Re: Two New Builds - Feedback on Pup Choices Please
« Reply #1 on: July 22, 2018, 02:22:00 AM »
Update since my OP:
« Reply #2 on: July 22, 2018, 05:07:01 AM »
I think you will probably be happy with the HD and BD.
The Sinners might overpower them though.
I would also consider Irish Tour or Slow Hand singles.
Cookie Monster
« Reply #3 on: July 22, 2018, 05:38:46 AM »
That's what I was thinking about the Sinners as well, so I figured the Trilogy Suites would be a better match, but would even those be too powerful to match with the Black Dog?
« Reply #4 on: July 22, 2018, 09:45:37 AM »
I can't really answer that.  Telerocker might drop in with an answer for you.  I'm not much of a single coil guy besides P-90s.
« Reply #5 on: July 22, 2018, 12:58:36 PM »
The Trilogies have a bit of a P90-vibe going, so they might be too powerful for a Black Dog, but will be a good match with the HD. The BD in an alder bolt on guitar is a bit of a gamble. This pickup has still quite some topend. Personally I don't think its the best choice for alder - maple neck.
I'm not a big NB-fan, especially for soloing. I like the HD better for that, because the solonotes keep more weight higher upon the fretboard.
If you want Sinners I suggest a combo with the Miracle Man, which has good mids, but they seem not to be so prominent bec of the huge bass. I like the treble voicing of this pickup. Not so abrasive as the NB.
Just my 2 cents.
Cookie Monster
« Reply #6 on: July 22, 2018, 11:27:27 PM »
Just my 2 cents.
Great food for thought there. I will consider all of it. Thank you for sharing your experiences and insight. Much appreciated.
