Author Topic: Prs with Miracle Man Sound Clip  (Read 4333 times)
reilly
    • Imbued Music
« on: October 01, 2018, 05:14:34 AM »
I did a quick recording with the new Bare Knuckle Miracle Man Pickups I put in my 2004 PRS Standard 24 all mahogany. I used a PRS Archon 100w head with a Fractal Audio FX8 for effects. Running through a Suhr Reactive load using the new Ownhammer Friedman IR's. Tuning is Drop B. Figured I'd share.
https://soundcloud.com/michaelreilly/miracle-man
Suhr Modern Chili Red GG Spec
PRS Standard 24 w/BKP MM
Jericho Edge 6 Premium w/BKP Abombs
Friedman Runt 50w head with 2x12 & 4x12
PRS Archon 100w, Fractal FX8
www.facebook.com/imbuedmusic
Lucas
Re: Prs with Miracle Man Sound Clip
« Reply #1 on: October 03, 2018, 08:49:22 PM »
Sounds good, well done. I`m glad to see that Miracle Man is getting loads of attention here, as it`s my favorite pickup so far out of all BKP bridge models, I`ve tried. I`m just finishing my second song featuring Miracle Man set.
By the way if you look down below on forum main page, there`s a 'Players' section where you can present recordings.
Keep it up!
darrenw5094
« Reply #2 on: October 04, 2018, 03:00:15 PM »
Is the MM metal only or can it do Classic rock?
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Lucas
« Reply #3 on: October 04, 2018, 08:25:41 PM »
Trust me, MM can do classic rock and even heavy blues very well, it might give that edge and a little bit of modern twist, but not too much. Actually I find MM quite versatile, it`s not extreme metal pickup at all.
At the moment I`m finishing my second song (finishing the video to be precise) of MM set doing heavy blues/rock type of thing and it`s sounds amazing. I should get that finished this weekend.
If you`re interested check out my first song featuring MM set, it`s more hard rock/rock vibe:
https://www.youtube.com/watch?v=evlwXV3Dq5s
cheers
reilly
    • Imbued Music
« Reply #4 on: October 09, 2018, 02:10:59 PM »
I find them very versatile and can cover a lot of ground. Cleans are great too. The neck pickup is very fat sounding and they also coil split very well.
« Reply #5 on: October 09, 2018, 03:24:33 PM »
Yeah I have one in my SG Standard (in standard tuning, EADGBE) and I don't find it 'extreme' ... the output is more than the Cold Sweat but I can still get all the same tones out of it and then some because it has more bottom end if you want to dial that in.
Lucas
« Reply #6 on: October 09, 2018, 07:11:15 PM »
Totally agree, it`s not extreme pickup at all. Regarding neck model it is fat but thanks to hollow mids (just like bridge model) and sparkle in highs it`s not dull at all. It has it`s own character. At the moment I`m using way more MM neck than for example Cold Sweat in another guitar.
check video below, where MM set is doing some bluesy hard rock, both neck and bridge playing leads:
https://www.youtube.com/watch?v=a9TH3Sv9R-Q
« Last Edit: October 17, 2018, 08:58:42 AM by Lucas »
