Pickup Polarity Question
Started by rocco, April 20, 2006, 08:19:54 PM
rocco
Hi,
I went to London last month, and while I was there I bought a Bare Knuckle Apache set.. When I got home to Norway I opened the box they came in, abd started reading the doc. The doc says that the pickups have been colour coded on the base with a red dot for bridge, black for the RW/RP middle (stock polarity coloured green) and blue for neck.. I examined the pups, and I only found a Red dot.... The document also states the DC restistance for the bridge pup 6.6k , and the other two at 5.95k.
How do I determine where to put the other pups.
The serial number is AP0905..
Best regards
Torgeir Rokkones
Norway
Tim
Hi and welcome,
the set you've got are from when we used to use a coloured dot system to ID the coils..............you have a stock set, ie the mid coil isn't RWRP.So the red dot = bridge, the other two coils can go in mid or neck position(doesn't matter which way round).
Tim
rocco
Ok. Thanks for the quick reply.
I have already installed the pickups on my strat. Lovely tone.
I used a vintage wiring schematic, cloth wire, Orange Drop o.47 cap, and some quality pots.
I have been in tone heaven since:)
Add some Snake Oil strings and a Vox AC15!! Pretty close to the Gallagher tone on some of his recordings..
Cheers!!
Apaches are terrific aren't they- great stuff.
