Author Topic: Alnico V Neck Humbuckers from Brightest to Darkest  (Read 9595 times)
brianhenson
« on: January 09, 2019, 11:04:03 PM »
I've scoured the forums and emailed back and forth a bit with Ben and Tim and decided I'd attempt to list the lower output AV humbuckers in the BKP range by brightness, as well as by "bassyness" (totally not a word). Let me know if you agree and/or if you find it useful:
AV necks (under 8.5k) by brightness (brightest to darkest):
Riff Raff
Holydiver
Cold Sweat
VHII
Rebel Yell
Black Dog
AV necks (under 8.5k) by bass response (most to least):
Cold Sweat
Black Dog
Rebel Yell
VHII
Holydiver
Riff Raff
This was part of my own search for a neck pickup that met my specs. In the end, I've decided I'm going to get a Riff Raff neck and compare it to the Stormy Monday I currently have. The Stormy sounds very sweet but I think I really want something a bit more "lively" and a bit leaner on the low end and since the Riff Raff is the brightest, tightest AV neck humbucker BKP makes, I think that will fit the bill for me.
« Last Edit: January 18, 2019, 06:39:56 PM by brianhenson »
Re: Alnico V Neck Humbuckers from Brightest to Darkest
« Reply #1 on: January 10, 2019, 02:59:39 AM »
Output can be deceiving.
1. you don't mention the Black Hawk neck, which is rated at 8.0k, or the Impulse neck, which is rated at 7.9k
2. the Cold Sweet neck is hotter than its rating suggests, on a par with the Nailbomb neck (which is brighter).
brianhenson
« Reply #2 on: January 10, 2019, 03:49:03 AM »
The DCR is all I have to go on since I don't have the inductance ratings and haven't tried any of the pickups in the list. I hadn't considered the black hawk or impulse since they're blade pickups and I've always thought of those as different beasts in my mind.
« Reply #3 on: January 15, 2019, 05:04:24 PM »
Riff Raff
Holydiver
Cold Sweat
Rebel Yell
VHII
Black Dog
Cold Sweat
Black Dog
Rebel Yell
VHII
Holydiver
Riff Raff
the brightness range sounds right, but the vhII is definitely bassier than the cold sweat, and perhaps bassier than all the others too
others might sound fuller in comparison due to its hollowish midrange
vincenz
« Reply #4 on: January 17, 2019, 08:43:10 AM »
Very interesting thread !
It seems to give me a solution to my neck pup quest.
I love the Black Dog bridge on my Les Paul R9, especially for his hot/throaty mids and presence. It does the perfect breakup on my EVH 5150 blue channel.
But I found the neck position too bassy, with not enough push and definition in de high mids.
Reading the forum, the Holydriver and the Riff Raff are the two I am actually considering for the neck position.
But I also wonder about the power output comparing the the BD bridge.
Any thought about my case ?
« Reply #5 on: January 17, 2019, 09:31:52 AM »
As a partner to the Black Dog bridge I would choose the Holydiver neck out of the two mentioned. Balance should be ok.
darrenw5094
« Reply #6 on: January 17, 2019, 07:03:30 PM »
There is a video on YouTube with a Les Paul.....Black dog in bridge and a Riff Raff in the neck.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
vincenz
« Reply #7 on: January 17, 2019, 07:36:47 PM »
Reading the forum, the Holydiver and the Riff Raff are the two I am actually considering for the neck position.
I saw that, Bruce Dickinson plays really great btw (if it's the video you mean).
The RR sounds good, but it seems to be a little weak beside of the BD anyway...
brianhenson
« Reply #8 on: January 18, 2019, 12:53:04 AM »
Riff Raff
Holydiver
Cold Sweat
Rebel Yell
VHII
Black Dog
Cold Sweat
Black Dog
Rebel Yell
VHII
Holydiver
Riff Raff
Interesting! I'd read that the CS had quite a bit of bass. So perhaps this would be closer?
Riff Raff
Cold Sweat
Holydiver
VHII
Rebel Yell
Black Dog
VHII
Cold Sweat
Black Dog
Rebel Yell
Holydiver
Riff Raff
« Last Edit: January 18, 2019, 06:50:30 PM by brianhenson »
darrenw5094
« Reply #9 on: January 19, 2019, 05:17:50 PM »
Yeah.....that's the one
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
