P90's replacing Mini HB's
Started by smudger123, April 22, 2006, 07:47:57 PM
smudger123
How easy is it to replace Mini HB's in say an epiphone elite riviera with BKP90's? I notice Tim has done this to his LP Deluxe in the gallery....
Bare Knuckle Pickups:- Country Boy set, Mule Bridge, Stormy Monday Neck, Riff Raff set.
Tim
Very easy as the mini hums use a P90 cover as a surround so the fit is perfect..............they should drop straight in.In LPs there's a plate at the bottom of the cavity which the min hum attaches to for height adjustment-the P90s also can screw into this.
Tim
The amazing Phil
Yeah, mini humbucker rings were designed to fit P-90 slots when Gibson had a load of left over mini buckers (from firebirds I assume) and gold P-90 routed bodies. And the Les Paul Deluxe was the result of Gibson's parts bin raiding. It turned out a bit better than the "leftovers" guitar Fender put out when CBS owned them that's for sure... :lol:
headtheball
Heard an original LP deluxe being played in anger at the weekend, back to back with a "the Paul". Surprised at how pokey and venemous the tone was. Might be considering this change in reverse....
Evil, Evil, Evil...
The Mini-Mules have a great tone.  Don't let the small size fool you, they sound much bigger than they are - Scott Gorham played a deluxe for a long time with Thin Lizzy.
smudger123
Mini Mules are of course another way to go...  :?
Can you get mini stormy mondays?
Thanks for the replys guys....
