Author Topic: Pedalboard Materials?  (Read 3353 times)
Brow
« on: April 26, 2006, 05:01:24 PM »
Hey guys.
I know this has probably been covered before, but in your opinion what is the 'best' material to make a pedalboard from?
I was going to make a simple 12mm thick plywood board with a lid, but thought it was worth posting on here to see if anyone had any better suggestions?
Craig
R/2e
    • http://www.ron2e.com
« Reply #1 on: April 27, 2006, 09:43:31 AM »
There is no right and wrong. I made mine from a frame of cheap Homebase pine covered top and bottom with thin ply from the back of an old wardrobe, and then a ply lid which lifts off, because that's what I had lying around. Bear in mind 12mm plywood will be quite heavy.  The pine supports the ply very well and I permanently mounted the power supplies inside with a side panel for power in and guitar in and out.
If it helps, TGM (The Guitar and Bass Magazine) did an article a  month or two ago about building a pedal board, their website is http://www.ipcmedia.com/magazines/guitar
you may be able to get a reprint or back issue from them.
Brow
« Reply #2 on: April 27, 2006, 03:40:40 PM »
Thanx for the reply :)
I have a subscription to that magazine you mentioned, and have read that article many times :D
That's where I got the idea from for using 12mm Plywood :)
Thanx again for your reply.
