Please excuse my scatty writing style but I hope you guys can help.
Last year I picked up an ex-demo Schecter KM-6 on the cheap. HH pickup config, single volume (push/pull coil split) and 3-way pickup selector affair. Swamp ash body, set maple neck with ebony fretboard. I use it in standard tuning.
Absolutely love the beast; best playing guitar I've ever owned but the stock Seymour Duncan 'Blackened' Black Winter set are just a bit...much. Or should I say, the wrong kind of 'much'.
I love that the bridge pickup is hot enough to drive the amp (or BIAS) and has that tight/fast tracking I need. I do actually quite enjoy it but as the name suggests, it can be treble city in a bad way. I could deal with the Duncan Distortion I had in another axe once but these blackened-y black black SDs have has this really intrusive c--ked wah tone; a very 'vowelled' sound, if you will. Kinda like a 'nang' sound is how I would describe it. Others found the same. I don't know how much the wood contributes but it would make more sense that the pickups are the main culprit. Then again I'm all ears if you think otherwise. One guy on the Sevenstring forum said he had the same issue even after replacing the pickups and ultimately had to sell it on but I'm not giving this beautiful beast up without a fight.
So anyway, if I want this in each respective pickup:
BridgeA tight-tracking, "drives the amp" modern metal affair, so strong preference for ceramic
Cleans up nicely with enough headroom (i.e.
not the Juggernaut judging by experience)
Not overly bright; that said, while I love the ceramic Warpig in my basswood Ibanez RG321, something like that a teeny notch or two brighter for a bit of contrast wouldn't go amiss (unless the swamp ash might compensate), not to rule out the Warpig completely
NeckSuitably matched in terms of output with your bridge recommendation
Able to get those creamy soaring sustained notes but also good at handling flashy legato, with not too much scratchy treble coming through
Also cleans up nice
What would you guys suggest?
My initial thoughts would be:
- Warpig set (ceramic bridge)
- Ragnarok
The partial reason I'm thinking of those is they might be sufficiently not-overly-trebly to counteract the problems I'm having with the SDs.
Like I said, my only reservations about another Warpig set is that I
might want something less bassy and with a slightly brighter 'zhuzh' (unless again the body wood is a big factor). As for the Ragnarok, does the neck pickup meet my criteria? If not, what would pair well with a Ragnarok bridge, or perhaps you'd suggest an entirely different set?
Let me know your thoughts! I hope I haven't been too weirdly specific, hard to understand or plain stupid
