Author Topic: Set for 335  (Read 5312 times)
Guitar 2020
Set for 335
« on: April 10, 2020, 01:32:40 PM »
Hi All,
I am looking for a new set for my 335. Right now it has the stock classic 57’s and they are a bit dull in this guitar.
For: Holdsworth type (with gain) single note solos, and also very clean jazz soloing.
Abraxas? Needs tight bass. Also my 335 is on the bright side. Can’t get too “fizzy” when playing solos with gain.
VHii? Looks a bit bright.
Thanks much!
Guitar
« Last Edit: April 10, 2020, 01:34:21 PM by Guitar 2020 »
Re: Set for 335
« Reply #1 on: April 11, 2020, 03:26:07 PM »
The obvious call : Stormy Mondays. Maybe Mules.
Guitar 2020
Re: Set for 335
« Reply #2 on: April 11, 2020, 10:49:10 PM »
Can stormy mondays handle fusion soloing with gain?
Guitar 2020
Re: Set for 335
« Reply #3 on: April 11, 2020, 11:05:08 PM »
If possible, I want something in the vintage hot category. I want a bit more output.
Re: Set for 335
« Reply #4 on: April 12, 2020, 12:35:08 AM »
All BKP's handle gain well. I play everything with Mules (which have a subtle emphasis on the mids). But go Abraxas if you want to keep PAF-flavour but need a little more output, mids and less topend. You sacrifice a bit of openness and dynamics of the Mule though.
Guitar 2020
Re: Set for 335
« Reply #5 on: April 12, 2020, 01:48:22 PM »
Thanks. Are there any other differences between the Abraxas and mule? Some people say the Abraxas is lacking in low end and is too bright, brittle/thin.
How is the low end in the Abraxas? Is it really tight with gain?
Re: Set for 335
« Reply #6 on: April 13, 2020, 12:08:43 AM »
The pickup height is very important with scatterwound pickups. I think people who say the Abraxas is thin have not set them right. The Abraxas is a beefed up Mule, so low end should be tad bigger, mids are a little more pronounced and the topend is more rounded. I heard great hardrock/metal clips with the Abraxas. It's not a metal pickup, but it can do a lot. I play classic rock/hard rock with Mules. It also depends on how tight the low end of your amp is.
You always can contact Ben at BKP for a recommendation.
