Author Topic: P90 Recommendations for a Tele  (Read 6796 times)
dyanswer
« on: June 07, 2020, 11:03:08 PM »
Hello,
I'm looking for recommendations/combo suggestions on how to place/pair P90s with single coils. Can a P90 pup be coil tapped with a push/pull pot?
The pickups are for a Custom Tele I'm building, I still haven't decided on the wood but it is probably gonna be either alder or ash with a flamed maple fretboard.
The sound I'm looking for is something versatile with more punch/ higher output than the usual Tele, without losing the "vintage" sound. Also, never had a guitar with P90s, so I'm open to being told it is a bad idea, and that I should go for lets say Piledrivers. Not trying to emulate anyone's sound but I've always liked the Wirebirds Countour of Jo and Dez from Good Tiger/The Safety Fire.
I listen mostly to prog and death metal, but I listen and play a fair share of other stuff, and already have guitars to handle those.
Proud Bareknuckle user since 2018 in here. Got a custom Strat HSS with a Cold Sweat and two Trilogy single coils, and it sounds superb. Going to dive further into them, I also have an Aristides being built right now.
Every input/advice is gonna be well received.
Sorry If this topic has already been discussed, I just couldn't find anything on search.
« Last Edit: June 07, 2020, 11:19:08 PM by dyanswer »
BKPs:
Cold Sweat & Trilogy Suite - HSS Fender Custom Strat
Painkiller  /  Brute Force Tele  - HS Custom Telecaster
PRS Custom 24 - Silo Set
Aristides BKP Custom / Cold Sweat Neck - HH Aristides 07
Re: P90 Recommendations for a Tele
« Reply #1 on: June 08, 2020, 12:40:42 AM »
You can coiltap a P90 to reduce the outputvalue.
https://forum.bareknucklepickups.co.uk/index.php?topic=13457.0
If you're looking for a vintage tele-sound with balls, I would definitely look at the BKP Flat 50's.
Yet, P90's do very well in tele's too. A Nantucket or Supermassive can cover a lot of styles.
dyanswer
« Reply #2 on: June 11, 2020, 02:56:28 PM »
Thank you very much,
Looking already at the BKP Flat 50s, gonna look into he Supermassive and Nantucket aswell.
Would you recommend having a P90 on the bridge and a single coil in the neck? I've never seen that kind of setup. is it too crazy?
I wonder if i should just go with a HB in the bridge and a single in the neck.
BKPs:
« Reply #3 on: June 11, 2020, 03:39:15 PM »
It is usually done the other way around: tele-single coil at the bridge, P90 in the neckposition. I guess because a bridge P90 will overpower nearly any tele-neck single coil.
« Reply #4 on: June 12, 2020, 12:59:55 AM »
Yeah I wouldn't match a Tele neck with anything other than a pretty calm single coil in the bridge, definitely not a P-90 in the bridge with a Tele neck
dyanswer
« Reply #5 on: August 06, 2020, 05:33:57 PM »
Thanks, after careful consideration I ended up getting the highest output Tele Coil Boot Camp in the neck and a Painkiller HB, to try it out. I think it adapts better to my style of playing. I'm looking forward to hear your thoughts about this.
I guess the P90 in the neck balances out with the single coil bridge output, so It makes sense.
Is it a matter of preference? or just the dynamics of the combination that doesn't make sense to you? I'm curious.
I may go in the future for a Tele bridge coil to pair it with the brute force single on the neck, or just swap the whole set for something more vintage sounding.
BKPs:
« Reply #6 on: August 07, 2020, 01:54:39 AM »
I just think that the Tele necks would tend to be overpowered by a P-90 bridge
Personally I think a Supermassive neck would work nicely with a Piledriver bridge.
Brow
« Reply #7 on: August 11, 2020, 11:24:41 AM »
I have a Piledriver bridge paired with a Nantucket neck and that balances fine.
