MM's for a lp?
Started by snipesace, April 30, 2006, 06:45:25 PM
snipesace
alright alright, so I know, this has been discussed plenty of times I am sure, but I want a good clean answer before I invest my money.  I have a 2002 LP standard, bustbucker pro's just arent doing it for me, I have been looking at a set of miracle man pickups but here is my question. would that be too bassy?  I enjoy sabbath and ozzy of all time periods, the clips of the miracle man pickups of the ozzy tribute band sounded great, and I assume he has miracle mans in a les paul. I play all kinds of classic rock, to more modern stuff, with 80's in the middle, my amp is a boogie dual rec, would the mm's be the right direction, or am I going the wrong way?
Welcome. The MM is made with a Les Paul in mind. The ceramic magnet keeps the bass tight. It should sound pretty good through a Mesa.
For your styles of music, you might want to take a look at the Cold Sweat as well.
I think that the Miracle Man will have NO problem doing any of the genres you mentioned!
downrodeo
The Miracle Man would be one of my no.1 choices. Actually, I can't think of many BKPs that wouldn't sound good in an LP.  :lol:
Steve-Mr Pig 2U
The Miracle man set sounds great in Les Pauls, and would do what you want nicely. As Ratrod metioned, the Cold sweat would be worth considering too. Its got a slight more vintage edge with a more open organice tone.
Quote from: Steve-Mr Pig 2UThe Miracle man set sounds great in Les Pauls, and would do what you want nicely. As Ratrod metioned, the Cold sweat would be worth considering too. Its got a slight more vintage edge with a more open organice tone.
I would agree with this; the Cold Sweat has an openness in the upper midrange that is really great if you want to add a nice growl to your tone.
snipesace
alright, sounds great, thanks for the replies guys, I shall take all that into consideration
downrodeo
It's tough taking all the opinions into consideration. Believe me, I know. Hopefully they sound good to your ears, and good luck with 'em!
