Author Topic: 2018 Schecter C-6 Pro with alnico Black Hawk set  (Read 29810 times)
« on: September 20, 2020, 10:44:30 AM »
I got this guitar second-hand for a steal on Gumtree recently and then installed a Black Hawk set into it.  I removed all the old wire from the Schecter harness and rewired it with new wire.
Re: 2018 Schecter C-6 Pro with alnico Black Hawk set
« Reply #1 on: September 22, 2020, 12:48:54 AM »
Nice catch Dave. Oozes nineties vibe! Those axes always makes me hungry for a pointy headstock. I had a early Jem FP 77, with the original cloth under the lacquer and of course Steve's DNA-dust ))). I traded the Jem for a telecaster because I went vintage and that tele sounded just better on or maybe connected better with the Rivera amp I had in those days. But I should have kept the FP 77. It would be collectible now.
« Reply #2 on: September 22, 2020, 10:15:37 AM »
Cheers, yeah I've never had a reverse headstock before
« Reply #3 on: September 23, 2020, 02:45:42 AM »
Mind you, I had a Jem and a Gibson MIII with reversed headstock as a backup guitar. In those times I traded a lot. When I was done with FR-style guitars the MIII went for a Ibanez AS 120...
« Reply #4 on: September 23, 2020, 04:32:55 AM »
By the way I had to reshape the feet and drill them out for the philips head bolts used on the Schecter direct mounting.
To do this I simply threaded the BKP pickups screws right down in the Black Hawk and flipped it over, using it as a jig with the Schecter Diamond Decimator pickup over the screws so that I could shape the Black Hawk fit to match with a file and drilled the screw holes out with a 3mm drill bit.  Then I glued the rubber blocks from the Schecter pickups to the bottoms of the Black Hawks
« Last Edit: September 23, 2020, 04:39:04 AM by Dave Sloven »
« Reply #5 on: January 21, 2021, 01:10:33 PM »
I've added all Gotoh hardware since then.  Has turned into a very nice guitar.
Gotoh 510-FX6 bridge in black
Gotoh SG381-MGTB limited edition all-black locking tuners
Gotoh VK-18 knobs in black
DiMarzio ClipLock strap system as on most of my guitars.  Is proving to be a very nice sounding and playing guitar.
one
  • Nailbomb, Cold Sweat, Warpig, Juggernauts
« Reply #6 on: January 22, 2021, 07:12:10 AM »
Cool guitar!
