Author Topic: Dual HB Inner coils series / parallel with 5-way switch, dual vol  (Read 43568 times)
david.lightman
Is it possible to wire dual humbuckers with 500k & 250k volume pots on a 5-way switch to have:
1) Bridge 500k
2) inner coils series 500k
3) Neck Bridge Parallel 250k
4) Inner coils parallel 250k
5) Neck 500k
No tone pot (don't judge me).  I've done quite a bit of searching on the interwebs and haven't quite found my answer.
Mentor
Re: Dual HB Inner coils series / parallel with 5-way switch, dual vol
« Reply #1 on: February 09, 2021, 01:15:53 PM »
Hello,
I'd like to have some details to try to make it
Can you Confirm :
1) Bridge 500k --> cap 47nf
2) inner coils series 500k --> cap 47 nf
3) Neck Bridge Parallel 250k --> Neck AND Bridge in Parallel should be 500K cap 47nf
4) Inner coils parallel 250k --> cap 22nf
5) Neck 500k --> cap 47nf
Nota for positions 2 and 4, one of the two humbuckers have to be reversed (turn 180°). If not these positions will be not hum cancelling.
Regards
Mentor
Mentor
« Reply #2 on: February 09, 2021, 04:26:34 PM »
See the image
 1 is for on
Mentor
« Reply #3 on: February 09, 2021, 04:38:42 PM »
Note :
Neck humbucker is reversed
Coils not indicated 1 (on) are off (0)
Example : pos II Bridge south coil is off and Neck north coil is off too
« Last Edit: February 10, 2021, 10:44:50 AM by Mentor »
Mentor
« Reply #4 on: February 11, 2021, 08:49:14 AM »
Please find the schematic diagram for wiring.
Mentor
