November 26, 2026, 01:02:45 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Pickups
Pre-wired pickguard installation
Started by Sam Chadwick, February 08, 2021, 04:02:03 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Sam Chadwick
Strawweight
BKPs:
Logged
Hi all, has anyone bought one of these from BKP? what is the installation process - does it require much soldering etc?
Good to be back on here it's been a long time!
Welterweight
Logged
Re: Pre-wired pickguard installation
#1
February 08, 2021, 11:16:55 PM
t's a pre-wired pickguard, so you would just have to solder the two wires to the output jack
Sam Chadwick
Strawweight
BKPs:
Logged
#2
February 09, 2021, 11:15:54 AM
is one of those 2 the ground? a guide i read mentioned some strats have 2 ground wires, not sure if this was in addition to 2 wires to output jack
Welterweight
Logged
#3
February 09, 2021, 12:02:14 PM
Oh you will will have to connect a ground wire from the bridge to the pot where the other grounds are located. On a Strat this will generally be from the claw. There might also be a ground wire that someone has added for the cavity shielding (if present).
JJretroTONEGOD
Welterweight
JJ Retro w/Mule + BKP90
Logged
#4
February 20, 2021, 12:45:23 PM
Last Edit
: February 20, 2021, 12:47:54 PM by JJretroTONEGOD
have you sheilded your guitar with conductive tape or paint? if not I recommend doing it and then hooking up the kit, which should be just connect to the output jacks as dave said.
Print
Go Up
Pages
1
User actions
Forum Ringside
Pickups
User actions
Print
