Author Topic: did this order come correctly? The Mule  (Read 8292 times)
1983strat
« on: March 06, 2021, 01:33:39 AM »
Hi guys
after reading the feedback here, I finally put an order on my 3rd pickup set, which is The Mule for my LP
However, I'm wondering if my order was fulfilled correctly.
Usually, pickup screws are apart from each other, like so:
my pattern looks (top to bottom)
  • screw - bolt
  • screw - bolt
Notice that both screws are facing "up", so they are not as far apart like the example above
while the color looks correct, shouldn't it be
  • screw - bolt
  •   bolt - screw
Thanks
« Last Edit: March 06, 2021, 02:23:59 PM by 1983strat »
Kotsos81
  • BKPs: A-bomb (b) / VHII (n), TG set.
Re: did this order come correctly? The Mule
« Reply #1 on: March 07, 2021, 04:01:05 PM »
I think that the white part of the pickup should face towards the neck in the case of the neck pickup and towards the bridge in the case of the bridge pickup, i.e., you have white at the outer layer and black at the inner one. Then, the pattern is screw-bolt-bolt-screw.
Anti-intellectualism has been a constant thread nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'
Isaac Asimov
b.gandt
« Reply #2 on: March 07, 2021, 04:22:16 PM »
Looks good.  Screws go to the outside, that is, next to the bridge and neck.  White is on the outside on both, which is standard from what I've seen.
Here's some reading on how players will sometimes change from the norm.
https://www.giggear.co.uk/blog/articles/zebra-vs-reverse-zebra-pickups.htm
« Reply #3 on: March 07, 2021, 05:33:47 PM »
Mail the BKP-team and you know!
b.gandt
« Reply #4 on: March 07, 2021, 08:17:56 PM »
Agree, mailing them is always the best idea!
« Reply #5 on: March 08, 2021, 01:58:38 AM »
I think what's confusing you is that some pickups have different baseplates for bridge and neck.  BKPs don't, so one of the pickups always looks upside down from the back
Both slug coils are black, that is correct
1983strat
« Reply #6 on: March 08, 2021, 04:45:24 AM »
thanks guys
I heard back from BKP. The poles are apart and my order came wrong. It was supposed to be reverse zebra but came regular zebra
« Reply #7 on: March 08, 2021, 05:43:50 AM »
The difference between zebra and reverse zebra is that on reverse zebra the slug coils are white and the screw coils are black.  The slug coils still face one another.  With reverse zebra white is on the inside and black faces the bridge and neck
