Author Topic: Black Dog -- With a little more power?  (Read 16699 times)
CLund
« on: June 05, 2021, 08:28:37 PM »
So after trying out 5 different Bridge HBs from Bare Knuckle, 4 different HB from Suhr.  I'm still not completely there.   So simple ask from the Bare Knuckle experts out there.   What pickup would be closest to a Black Dog with a bit more power?   I really like the low/mid growl of the Black Dog, but wish it could push a little harder.   Don't want too much power though, I think my Suhr SSH+ and the Charvel GG MF Custom humbuckers are just a bit too strong.   Something in the sweet spot say 12-14k range.    Would that be a Crawler?  Abraxas?
Thanks for any advice!
- Corey
RobAbrams84
Re: Black Dog -- With a little more power?
« Reply #1 on: June 06, 2021, 02:27:16 AM »
Have you tried the Holydiver?  It's not quite as hot as a Suhr SSH+ in my opinion.
CLund
« Reply #2 on: June 06, 2021, 04:12:10 PM »
Have not tried the HD yet.   The description sounds like a beefed up Black Dog for sure.  Thanks for the suggestion.
« Reply #3 on: June 07, 2021, 01:10:13 PM »
true grit (punchier and a little more balanced) or holy diver (more compressed)
both are are quite beefy and have a lot of the black dog dense midrange texture
Alfi27
« Reply #4 on: June 12, 2021, 12:00:49 PM »
Which guitar is this for? I would never put the Holydiver in a Les Paul (again), tried it briefly when my Black Dog was at BK for wax potting and it was a horrible muddy mess... And my LP is a fairly bright one as well. If you need to have the mid range character of the Black Dog I honestly don't think any other pickup will do it, certainly not without altering other things. But if you can get by with a more balanced mid range the Emerald is a little hotter and sounds fantastic, the 'Dog used to my all time fave Bare Knuckle but after getting the Emerald I'm not quite sure.
« Last Edit: June 12, 2021, 12:08:18 PM by Alfi27 »
« Reply #5 on: June 13, 2021, 03:13:36 AM »
I would have thought that the alnico Nailbomb is closer to the Black Dog than the Holy Diver would be
RobAbrams84
« Reply #6 on: June 13, 2021, 08:51:58 PM »
You might be right, I think it depends on what qualities of the Black Dog someone is after in a way.  I think that the Holydiver has a more similar EQ, but the Nailbomb is more open and aggressive and raspy.
 True Grit might be the best, depending on how much compression is wanted (it's only mildly compressed to me).
« Reply #7 on: June 14, 2021, 02:52:54 PM »
having replaced all the three of them directly, I gotta disagree
to my ears, there's this midrange texture in common between the dog and diver (and true grit) that feels different from the nailbomb more crackling glass aggressiveness
the dog sounded relatively raw, but had this dominating center mids that's a lot like the holy diver, but without the compression
I think the true grit is a great alternative as a middle ground between raw mids and juicy compression
I'd compare the alnico nailbomb to the vhII, as I tend to relate the rebel yell as "a riff raff with built-in a tube screamer"
« Last Edit: June 14, 2021, 03:03:51 PM by ericsabbath »
CLund
« Reply #8 on: June 17, 2021, 03:20:25 PM »
Greatly appreciate all the pertinent details on these pickups.    I am tempted to just order them all and keep trying them out.    Holy Diver is definitely on that list, True Grit as well and even the Emerald.
RobAbrams84
« Reply #9 on: June 18, 2021, 05:34:37 PM »
I sent you a PM, just fyi.
CLund
« Reply #10 on: June 18, 2021, 05:50:21 PM »
Thanks Rob....   I messaged you back.
So I did a random order, kind of a Grab Bag!    Found a guy selling a BKP bridge, contacted him and he has NO idea what pickup it is...   Told him I will take it anyway if he comes down on the price.   He did - so I bought it.      Reads 16.2k DC - so my guess is maybe a HD, but not sure.    Going to put it in something and see how it sounds!
https://reverb.com/item/35538256-bare-knuckle-53-mm-humbucker-carbon-fiber-tattoo-cover-bridge-humbucker
« Reply #11 on: June 19, 2021, 05:50:16 AM »
Is it 53mm?  If so it is definitely a bridge pickup.  It might have the tag 'bridge' on it still.
If it is 50mm it could possibly be a Ragnarok neck.  They were a thing with the carbon fibre covers
CLund
« Reply #12 on: June 19, 2021, 02:15:30 PM »
He told me it's 53mm - and it does have the bridge tag on the wires.   So what is a 53mm/16.2k bridge?
« Reply #13 on: June 19, 2021, 02:58:57 PM »
There are none that exact measurement on the site, but then measurements can vary slightly due to weather and all kinds of stuff.  The following are in the ballpark (out of those that have a single row o screws):
Crawler (15.4 kΩ)
Painkiller (15.6 kΩ)
Nailbomb (15.7 kΩ)
Holy Diver (15.9 kΩ)
Miracle Man (17.5 kΩ)
Out of these the closest (and most likely) is the Holy Diver, but it might also be a Nailbomb or Painkiller.  I could pick those three apart by ear though.  The Holy Diver is smoother sounding than the other two.
RobAbrams84
« Reply #14 on: June 19, 2021, 07:06:48 PM »
Just FYI, but my 53mm Holydiver bridge pickup reads 15.25 kOhms (I just measured it, not currently installed in a guitar).  Obviously there will be some variation from pickup to pickup, but I don't think that DC resistance is a great way to identify the pickup, especially when so many are listed as so close to one another.  I understand that there's not much else to go by sometimes, though.  It's too bad that they don't have a sticker on the back, at least!
« Last Edit: June 19, 2021, 07:13:10 PM by RobAbrams84 »
