Author Topic: Pickup spacing  (Read 2857 times)
Dan1990
Pickup spacing
« on: May 07, 2006, 01:36:45 AM »
What exactly is the pickup spacing? i know the humbuckers have the choice of 50mm or 52mm but how do i find out what spacing i need?
OD-Black_Fire
Pickup spacing
« Reply #1 on: May 07, 2006, 01:43:12 AM »
Measure the distance between the first string and 5th string at the bridge. Fenders are a bit wider because of their tremolo, I believe Floyd Roses are also. Those gibson bridges are 50mm.
Pickup spacing
« Reply #2 on: May 07, 2006, 12:40:34 PM »
^ isn't it the distance at the pickup?
Skybone
Pickup spacing
« Reply #3 on: May 08, 2006, 05:24:04 PM »
It's the distance between the 1st string and the 6th.
Gibson type guitars are usually 52mm, where Fender type guitars (I assume) are 50mm.
Bibble.
Searcher
Pickup spacing
« Reply #4 on: May 08, 2006, 05:27:07 PM »
Quote from: dave_mc
It's both.  The centres of the pickup poles should be in line with the strings.
Quote from: Sifu Ben
Searcher
Pickup spacing
« Reply #5 on: May 08, 2006, 05:27:38 PM »
Quote from: Skybone
Other way around, actually.  ;)
It can vary slightly though.  I've seen some trem-equipped guitars that are about 54mm and some non-trems that are spaced at around 48mm.  It depends where you measure as well.  The neck spacing can be fractionally different to the bridge.
