Author Topic: string height  (Read 6623 times)
mia
string height
« on: May 11, 2006, 09:11:44 AM »
What are the benefits of low or high string height... find that my guitar has it too low?...how do i alter it?
n_mountain
    • http://www.nordberg-music.com
string height
« Reply #1 on: May 11, 2006, 09:48:16 AM »
Low string height:
-easier to play
-harder to bend
-more buzz
-depending on how bad the neck is, possible dead notes...
-and, harder to play slide
High string height (and I'm talking reasonably high ;)):
- more or less the opposite :)
Your guitar's bridge probalby has some screws to alter the height, either for the whole bridge or for each saddle, depending on what bridge you have.
Jonesy
    • http://www.myspace.com/rory_boy
string height
« Reply #2 on: May 11, 2006, 09:51:47 AM »
its an edge pro
Thanks for teh info btw
Nailbomb - Mississippi Queen - Mothers milk
n_mountain
string height
« Reply #3 on: May 11, 2006, 11:34:24 AM »
Ok, you can heighten the whole Edge Pro, see the attached picture...
blue
string height
« Reply #4 on: May 11, 2006, 08:16:50 PM »
yes, you CAN do that, but i would suggest loosening the strings first to take tension off the knife edge before you start grinding a metal post against it!  i did do it once without loosening, and it doesn't seem to have done any harm, but better safe than sorry, although it is a hell of a hassle with a floating bridge.
Jonesy
string height
« Reply #5 on: September 29, 2006, 08:37:12 PM »
Thought I may aswell add onto this thread...How much does string height matter..getting the sweet spot I mean?...I dont know if I have found it or not?
A mississippi queen nech, Mothers milk middle and Nailbomb bridge, what kind of heights should I be looking at?
Cheers,
Rory.
Jonesy
string height
« Reply #6 on: September 30, 2006, 04:51:08 PM »
I mean pickup height :roll:
string height
« Reply #7 on: September 30, 2006, 05:51:45 PM »
string hight has a lot to do with a guitars tone as well. The higher the strings, the more you get out of the guitars wood, the lower the strings, the more its just pickup.
string height
« Reply #8 on: September 30, 2006, 09:48:10 PM »
^ yeah, you get more sustain with higher strings.
