Author Topic: Should I try something more bright? (sound examples)  (Read 6656 times)
Ivanickson
« on: June 01, 2023, 03:18:41 AM »
Hey guys! I dropped here 3 examples with 3 different sets in my ash rgr652: Silo with covers, C-bombs without covers and Unity with covers. I used the same NDSP Nolly preset for each and seems like my guitar just sounds dark with a lot of low end.
I can get a nice sound from this with a few eq moves, but probably it will be better to try Painkiller or Aftermath or smth else for more tight, biting and bright tone without eq? Usually I play modern metal things, not sure I need just the djent tone but it would be nice to get well balanced percussive sound without muddy lows.  :smiley:
Btw I like C-bombs output of this 3 examples.
« Last Edit: June 01, 2023, 03:29:13 AM by Ivanickson »
timmy_b
  • BKP
  • The OTHER Tim and tech at Bare Knuckle Pickups
Re: Should I try something more bright? (sound examples)
« Reply #1 on: June 05, 2023, 02:48:27 PM »
Do you know what resistance value you are running on your volume pot? Switching out to the BKP 550k pots should give you a bit more crisp brightness with any set, if your standard pots are on the low side.
Hi all, yes, it's another Tim! I'll be here to answer any questions you want to throw at me, here or via sales@bareknucklepickups.co.uk
Ivanickson
« Reply #2 on: June 05, 2023, 08:30:30 PM »
Hey, thank you for your answer! Now I use just the BKP 550k volume pot, Silo and Unity were recorded with it. I usually keep pickups at 1-1.5 mm from screws to strings and 2.5-3mm from cover to strings, so it seems like it's the maximum possible brightness for my guitar.
timmy_b
  • BKP
« Reply #3 on: June 06, 2023, 11:02:44 AM »
That's pretty close to the strings; I would definitely have a play with running the pickups a little bit lower and you might well get a bit more clarity
