Author Topic: Issue with Nantucket HSP90 set  (Read 6639 times)
farleyuk
« on: June 23, 2023, 01:48:37 PM »
Hey all,
I'm having a bit of trouble getting the sound I'm looking for from a new set of humbucker sized P90 pickups I've just purchased.
I've always played guitars with humbuckers in, and never thought about trying other 'types' of pickups, until I jammed with Phil X - and his P90 SG sounded absolutely nuts.
These Nantuckets are in a Gibson SG 2020 model, but they don't sound as punchy or fat as I would have expected. They were recommended by Bare Knuckle, based on a video I sent of Phil X playing.
Can anyone give me any guidance please...? Am I missing a trick here? I would have thought they need to be closer to the strings due to being a single slug, but it sounds like I'm getting string pull if they're around 2mm.
b.gandt
Re: Issue with Nantucket HSP90 set
« Reply #1 on: June 29, 2023, 09:49:56 PM »
I use a Nantucket in the bridge of a Hamer.  Vintage output, crunches nicely when pushed.
From what I listened to, if he’s using a vintage level P 90, he’s getting help in the overdrive department from his amp rig.  Using a vintage level P 90 or humbucker and getting a lot more OD from the amp rig is not uncommon, and can sound quite good.
What’s your amp?
I had to look him up btw.  Wow!  Talented guy, and a good sense of humor to boot!
b.gandt
« Reply #2 on: July 27, 2023, 09:59:09 PM »
I guess the problem has been solved!
