Author Topic: Crawler split volume drop  (Read 5012 times)
Iced Dragon
« on: January 28, 2024, 11:21:10 AM »
Hi all,
I have a Crawler bridge, which I had put in a Hamer Centaura. One of the reasons I chose this one because it splits nicely. I recently put it into an EBMM Silhouette, and it appears that the single coil split is much more silent than I recall from the Hamer installation (and a previous installation in the Silhouette). The volume drop from humbucker to SC is very noticable. I also have a Stormy Monday neck in the Silhouette where I apply the same principle. The volume drop is negligible, and the SC is much louder then the split Crawler.
I replaced the Crawler with a Dimarzio AT1 in the Hamer, and there as well, the split is not very much dropping in volume.
Am I possibly losing some signal, or do I remember the Crawler split volume incorrectly?
Thanks.
Cold Sweat b&n (RR1, Dinky)
HD + Trilogy (Hamer Centaura)
Sultans, Mother's Milk n (strat)
Flat '50s (CV50 Tele)
Abraxas, Sultans (EBMM Silhouette)
Stormy Monday, Crawler, Mule, '63s, Blue Note
RobAbrams84
Re: Crawler split volume drop
« Reply #1 on: January 28, 2024, 06:36:42 PM »
The first thing to do, of course, is to check the wiring.  Bare Knuckle uses different wiring color codes than Seymour Duncan, Gibons, etc.  The next thing to do is to measure the DC resistance of the total humbucker and then each individual coil, it could be that one of your coils is broken or partially shorted inside (so that you aren't getting the full output of that coil).
If that all looks good, make sure again that you are splitting the "correct" coii.  If you're using the bridge Crawler and splitting the outside/screw coii (the one closest to the saddles), then it's naturally going to sound more thin and quieter than the coil closest to the neck (in this case the slug coil).  So you could physically mount the pickup in reverse, or you could rewire it to activate the slug coil when split, not the screw coil.
Lastly if that all works correctly, then you can use some partial coil split resistors (I suggest Googling them).
