Author Topic: Reverend Airsonic pickup suggestions  (Read 23329 times)
fivestarhibernacle
« on: January 12, 2025, 07:11:50 PM »
I recently put a Polypaf in the bridge of a Reverend Airsonic W which sounds absolutely amazing. The guitar has: a very unique body style with a thick center block but thinner wings with F-hole type cutouts that go all the way through, a bolt on neck, and a bass roll off tone control in addition to the typical treble tone control. I can't say for sure how the body style is supposed to affect the tone, but according to Reverend it is supposed to lend both the long sustain of a solid body and resonances typical of a semi hollow body. The neck pickup currently in it is a hum cancelling P90 style pickup which in comparison to the new Polypaf leaves much to be desired.
Looking for any recommendations for a neck pickup that would balance well with the Polypaf bridge and do tones ranging from indie style ambient cleans, the solo to Another Brick in the Wall, to All Then Witches fuzz tones, to modern style high gain leads. Currently I'm between just the matching Polypaf neck humbucker and Mississippi Queen HSP90, but wondering if anyone else has had success mixing and matching with another type of pickup in the neck position with Polypaf bridge.
TIA for any advice. Can't recommend the Polypaf bridge highly enough for anyone else on the fence about it (if anyone wasn't already instantly sold from the demo vids out there).
timmy_b
  • BKP
  • The OTHER Tim and tech at Bare Knuckle Pickups
Re: Reverend Airsonic pickup suggestions
« Reply #1 on: January 20, 2025, 03:11:14 PM »
Both of the options that you mentioned there will do great in that guitar, but, if you're considering a P90, absolutely consider the Blue Note too - its smoother midrange and clear chime suit this kind of guitar down to the ground and would create a really nice balance with the PolyPaf. Glad you're enjoying your bridge humbucker so much!
Hi all, yes, it's another Tim! I'll be here to answer any questions you want to throw at me, here or via sales@bareknucklepickups.co.uk
