Author Topic: Ragnarok stratitis  (Read 42312 times)
alexwong0702
Ragnarok stratitis
« on: April 27, 2025, 08:58:40 PM »
I have a Ragnarok in my Strat. The Low E string seems to have a weird chorus like thing going on. Is this stratitis? Lowering the rag does seem to help but it needs lowering a long way to reduce it. Is there anything else I can do or do I need a lesser magnet pickup?
timmy_pix
Re: Ragnarok stratitis
« Reply #1 on: April 28, 2025, 10:13:46 AM »
Stratitis is a thing because the pole pieces are the magnets, hence why they can affect individual strings, and they have a much stronger pull than any humbucker could ever have because they're so much stronger and closer.
If the magnets in your humbucker were pulling on the strings, they'd pull on all of them evenly. That it's only affecting one string pretty much guarantees it's nothing to do with the pickup at all; I imagine the only reason lowering it is helping is because the signal is getting weaker so everything is less audible.
The first thing you need to do is change the string - it could just be a dud! Then you need to look at potential issues with the nut, saddle or a high fret somewhere.
BKPs owned:
Stormy Mondays, Mules, Emeralds, 10ths, Mothers Milks, Nantucket, Black Dogs, Holydivers, A-bombs, Warpigs, Sinners, Cold Sweats
alexwong0702
« Reply #2 on: April 28, 2025, 12:57:53 PM »
Good point, but I'm pretty sure lowering the Rag is reducing the effect with other pickups selected. I will go back and check again though. Thanks
