Author Topic: Tele suggestions?  (Read 35302 times)
Iced Dragon
Tele suggestions?
« on: October 01, 2025, 07:19:01 AM »
Hi all,
I recently got a Squier Classic Vibe 50's. Pine body, maple neck.
Overall, I'm quite happy with it for its price, stays in tune very well, and I managed to intonate it quite good. Nevertheless, I intend to upgrade it, including Gotoh In-Tune bridge/cutaway ashtray, pots, ... Machine heads can stay for now. Frets are a bit too small for my liking, but I can live with them.
It's my first ever telecaster, and never had played one before. So pickup-wise, I have no experience. The present ones are not too bad, but the neck is a bit dark and muddy (typical tele, as I understood?), and the bridge is ok, maybe a bit too bright, but could use some more edge to it.
I wanted a tele to extend the collection/sounds, and venture somewhat into country and funk (mainly to gain/expand my skills, not that I'm that much into country or funk) and have some nice cleans. I like the middle position!
So I'm looking for a set/mix that gives nice warm cleans in the neck, with good note separation, and a typical tele bridge (I'd say rather vintage than modern), but nothing harsh and not too hot (I think, I don't have a really defined idea yet since I lack experience), but it can have some edge to it/push the preamp somewhat if needed. Some twang is ok, still should sound like a tele, but mainly has to be versatile.
So, the guitar is intended for jazz, 80's pop/rock/funk (the latter maybe somewhat Prince-like?), and country. Mainly cleans, but being able to handle high gain is a benefit.
So I think I'd rather go nocaster/broadcaster type than 60's (too bright?), especially given the maple/pine combination
I originally thought of going for the Flat 50, but maybe the bridge is too hot and less suited for clean styles?
Is the Flat 52 still somewhat overwound compared to later era pickups? Or is the bridge too twangy? Are the 50 and 52 related, or entirely different beasts? Can you consider the Flat 52 still nocaster type of voicing?
What about the Yardbird set? Too much rock oriented?
Other (brands)?
I intend to mainly play them through a home-built blackface Vibro Champ/tweed amp.
Thanks.
« Last Edit: October 01, 2025, 08:22:45 AM by Iced Dragon »
Cold Sweat b&n (RR1, Dinky)
HD + Trilogy (Hamer Centaura)
Sultans, Mother's Milk n (strat)
Flat '50s (CV50 Tele)
Abraxas, Sultans (EBMM Silhouette)
Stormy Monday, Crawler, Mule, '63s, Blue Note
b.gandt
Re: Tele suggestions?
« Reply #1 on: October 03, 2025, 01:13:32 PM »
I’ve used the Boss bridge and the Flat 52 set.  I have not used the Flat 50.
The Boss is great, but it leans to a rock voicing, not that it doesn’t sound Tele, just a bit more of a rock Tele.
The Flat 52, IME, is pretty mild.  Sounds great, but pretty low output.  As described by BKP, there is a bit of a Strat character to the neck pickup, which I really liked.
My understanding is that the brightness, twangiest Tele bridge pickups came out in the 60s, which I believe is reflected in a BKP Tele set that reflects that era.
Iced Dragon
« Reply #2 on: October 10, 2025, 08:57:04 PM »
How does the '52 bridge compare to 'standard' tele bridges? How bright is is? Still more or less nocaster? Is there twang?
I don't really know how what to think about a 'more strat-like' neck pickup. Does it differ a lot from 'standard' tele neck pups? How does it compare to the '50 neck?
« Last Edit: October 10, 2025, 08:58:57 PM by Iced Dragon »
b.gandt
« Reply #3 on: October 13, 2025, 05:00:33 PM »
Apologies for the delay…
I’d say the 52 neck is somewhere between a Strat neck and a Tele neck.  I can tell that there’s a bit of a Stratty sound, but it certainly isn’t a Strat neck pickup.  I like because I generally find Tele necks pickups to be too warm, or even muddy when it’s a lower quality pickup/guitar combination.  That bit of Strat in the sound gives it a touch more clarity.
I’m talking about playing into an amp that is set for clean.
I’ve not played any flat 50.
Iced Dragon
« Reply #4 on: September 05, 2026, 09:00:00 PM »
Almost a year passed. Ben advised met the 52's for a versatile combo. So I bought a set of 52's but they sent me a set of flat 50's (not BKP themselves to be clear). Since I doubted between both sets anyway, I decided to keep them.
I was impressed by the neck, but I'm a cool lover of the bridge. Sometimes I like it, sometimes I find it rather dull. Certainly not as high output/fat as I anticipated. Might be the combination with my amp (some kind of DIY 5W Vibro Champ/Champ with 12" speaker (Eminence GA SC64 or WGS G12Q).
Anyway, I'm still curious about the 52's. I think I would still prefer a more classic Tele bridge sound.
How much does the '52 deviate from standard tele sounds (particularly the bridge)? They marketeer it as very unique. Is it something you can hear on records, or is it really unique in its sound and not used a lot?
On the other hand, the Fender CS Nocaster 51 set would be very much alike, for much less money. Has anyone compared these?
EDIT: I have to note that using a Nobels ODR1 sparked some live into the bridge. In the meantime, I have ordered a set of 52's, since I originally wanted them and listening back to the sparse clips on YT, I should have sticked to the original plan.
« Last Edit: September 09, 2026, 08:58:40 AM by Iced Dragon »
