Author Topic: Rebel Yell bridge 50mm vs 53mm  (Read 45471 times)
rbg
« on: October 28, 2025, 04:30:26 AM »
So I found something puzzling, maybe people can help me with. I have a quite dark sounding super Strat and I have been enjoying a RY in the bridge. Super nice sound sound, just love it. However that is a 50mm spaced humbucher. The screw/string mismatching was bothering me, but it is absolutely impossible to get a 53mm RY. A couple of weeks ago miracle happened and a used 53mm one showed up on a second hand marker... so I grabbed immediately. It arrived and to my deepest surprise it sounds quite different compare to 50mm version. Not as clean and not as tight. If you know the RY sounds so clean, it feels like you have one if those wiggly frets -- the guitar is like super intonated. So 53mm version is still clean and deep, but not like 50mm. I thought that maybe those used 53mm are not RYs. I opened the pickup and it has RY scratched in the corner of the bobbins under the magnet. It also has SS and 717 scratched. All look like my 50mm RYs. 50mm one measure 6.9kOhm and 7kOhm, where 53mm version is 7.35 and 7.5k. The difference in R would be explained by longer bobbins, I would guess. They have a little bit bigger offset, maybe that is? Or maybe RY was designed and optimized to be a 50mm humbucker. Any ideas, why the sound is different? Or it is just a regular difference between two hand wound pickups? Thank you.
Re: Rebel Yell bridge 50mm vs 53mm
« Reply #1 on: November 02, 2025, 07:52:44 PM »
my bridge Rebel Yell is 53m and 14.4k, somewhere between yours and your 50mm
it does make sense that a 13.9k pup might sound cleaner and tighter than one that's almost 1k hotter and same specs, but maybe the pole alignment might play some part in this
rbg
« Reply #2 on: November 03, 2025, 04:57:02 AM »
Thank you Eric. It is interesting. I also have two Crawlers that measures almost 1k apart. Two NBs I have measures almost 1k apart, and I actually prefer ~16.9k NB :-)
rbg
« Reply #3 on: November 04, 2025, 06:57:03 PM »
One more thing, is it known if RY neck uses 42awg poly wire or it is 43 poly wire?
« Reply #4 on: November 21, 2025, 05:02:19 PM »
Doesn't sound like 43 awg to me
Maybe 42.5 like the cold sweat?
Maybe 42?
It sounds middier and less bassy than the VHII and has a smoother top than the CS
Far different character from nailbomb and emerald, and definitely hotter than the mule and old guard
b.gandt
« Reply #5 on: November 22, 2025, 05:32:27 PM »
Odd.  I’ve always heard that a particular string or two will be weak in terms of volume, especially with vintage output humbuckers.  The only personal experience with out of alignment I’ve had was the treble side  of the bar of a Dimarzio X2N.  However, that pickup is so hot that it picked up the treble e string sufficiently.
timmy_b
  • BKP
  • The OTHER Tim and tech at Bare Knuckle Pickups
« Reply #6 on: December 02, 2025, 10:44:07 AM »
We do alter the number of turns between 50mm and 53mm versions, but a 53mm set will come out with a slightly higher DCR in almost all cases. It also has a physically larger coil, which will sound a little warmer and less punchy than a more compact 50mm coil set - not a dramatic difference, but certainly audible and could go a fair way to explain any difference that you're hearing between different sized pickups. I think it's a fair indicator of how precise and nuanced pickup building is!
Otherwise, the most likely variable between two sets is simply inconsisitencies in the wire / coating between different spools - potentially the two pickups you had could have been wound many years apart and, although our wire supply hasn't changed over the years, each spool will have a slightly different coating thickness, which we keep on top of and adapt wind counts as we go to mitigate any variance, but is always going to add in some level of variation, which would be the case for any coil, regardless of whether it's hand or machine wound.
Hi all, yes, it's another Tim! I'll be here to answer any questions you want to throw at me, here or via sales@bareknucklepickups.co.uk
