Author Topic: Ever try Riff Raff bridge as a neck PU?  (Read 4978 times)
djpatb
« on: August 10, 2026, 12:37:54 PM »
Just wondered if anyone has tried a Riff Raff bridge model in the neck position on a Gibson scale guitar?
On paper the RR bridge seems to have specs that I usually enjoy in the neck (A5, 8.2k, EQ curve), when mixed with a higher powered bridge PU. Any experiences with this? Thanks.
« Last Edit: August 10, 2026, 12:42:34 PM by djpatb »
Gibson SG + A5 Warpigs
b.gandt
Re: Ever try Riff Raff bridge as a neck PU?
« Reply #1 on: August 15, 2026, 08:10:31 PM »
Well, we’re interested in the same pickup, but different position!
Here’s a bump…
timmy_b
  • BKP
  • The OTHER Tim and tech at Bare Knuckle Pickups
« Reply #2 on: August 24, 2026, 04:31:38 PM »
The Riff Raff is certainly on the brighter end of humbucker voicings, so it'll definitely work just fine in the neck position. Dynamically, the bridge will perform much like the proper neck version, as they share identical architecture and magnet setup - the bridge just has a slightly hotter wind which will fill out the lows a little and produce a touch more output, but certainly well within the realm of a great neck pickup when paired with a hotter bridge.
Hi all, yes, it's another Tim! I'll be here to answer any questions you want to throw at me, here or via sales@bareknucklepickups.co.uk
