Please help a technophobe!
Started by Antag, May 18, 2006, 05:09:40 PM
Antag
I'm almost embarrassed to admit I don't know this but...
What you do you need in order to use a PC ro record/make music?  (when I say "make" I mean still playing a real guitar and/or bass but recording it on the PC and making the drum parts on the PC).
I've been thinking of replacing my old four track & while flicking through the Turnkey catalog it dawned on me that I have no idea what most of the stuff in it does (e.g. whats a "Firewire audio interface", what does all this stuff on the software page do? what do you use a mic preamp for?)
Of course, I'll probably just end up buying a Tascam DP01FX & use the PC for backing the hard disk up via USB, but I was curious as all this technology seems to have passed me by :D
froglord
Both Sound on Sound and Computer Music have special "recording for guitarists" specials out at the moment. Check 'em out at your local newsagents.
Egnater Tweaker 15
maxingwell
Computer Music is also quite good (or used to be - I haven't bought a copy in over a year).
MM set, warpig set, about to be fitted - custom 7 bridge 'pig, CS7 neck.
aisuru
a Firewire audio interface is an audio interface that connects through a Firewire port. Firewire is another type of interface like USB. basically, the interface is a way to get sounds in and out of the computer, so you can record them. like the line or instrument ins on a Tascam 4track.
a mic preamp is basically like the preamp on a guitar amp - amplifies the signal up to a line-level. many FW/USB interfaces have them built in.
the software varies. applications like Cubase, Sonar, Logic are all audio/MIDI sequencing/recording programs. they're what you actually record with, and what you use to sequence drums, for example. soft synths are software versions of instruments - so the computer runs a virtual synth, drum machine etc. - and are 'plug-ins' that require a host application like Cubase to run.
personally, i'm moving away from solely computer-based recording and getting more hardware.
