Author Topic: IF I....  (Read 2539 times)
WITH FULL DISTORTION
IF I....
« on: May 27, 2006, 02:42:27 PM »
wanted to buyt, or order an amp with a very Crunchy mids, clear, articulated and sustained Highs, and Tight, Kinda Fat (Bold to be more precise) Bass .... But, just a clean amp, only one stuff.
i mean, no pre, only a Power section, and a 2x12 cabinet. i mean... either a 2x12 combo  or a Head only(cause i already have a 4x12)
.. so i´ll use some distortion pedals as a pre amp.
which amp or which Configurations shall i ask the manufacturer ?!?!?!
$%&#ing Hails
J.P
thanks´in advance.
IF I....
« Reply #1 on: May 27, 2006, 03:27:12 PM »
if you plug straight into the effects loop 'return' on your 5150 that is what you will already have.
I would imagine that a typical distortion pedal wouldn't drive the PI stage hard enough - you could use something like a POD or other preamp into the effects return of the 5150 though if you want to bypass the 5150 preamp.
 :twisted:
IF I....
« Reply #2 on: May 28, 2006, 12:01:16 AM »
Huuuuuum, interesting
thank´s Man
