Author Topic: Tremsetter? Tremol-no?  (Read 7812 times)
namle
« on: June 10, 2006, 07:39:20 PM »
hi guys
as one of my thread before was asking about floyd rose... yes im very new to floyd rose so just wanna ask
is it necessary to have a tremsetter? i mean what exactly can it do?
and tremol-no have heard and saw the website seems to be pretty cool stuff... anyone got any experience??
and finally what are certain upgrades or mods can i do with a floyd rose? except the change bridge nut to graphtech because my bridge nuts seem to appear inwards instead of outward like certain other floyd rose bridge
'For the Real Tone is at the Fingers'
CaffeineJunkie
« Reply #1 on: June 12, 2006, 10:51:32 PM »
try an EVH Drop D-Tuna, comes in very handy (i'd imagine, never used a floyd rose myself, so i wouldn't know :?)
« Reply #2 on: June 12, 2006, 11:18:58 PM »
The EVH Drop D-Tuna only works if the Floyd is set against the body - NOT floating - (floating is when you can pull-up / raise pitch as well as drop).
Upgrades shouldn't be needed - it just depends on which model Floyd you have - Original / Ibanez Edge / Licensed Other.
With the Edge/Edge Pro many things can be changed but only if you wish as it is a great trem outta the box.
A tremsetter is not "needed" for any if they are set up right - some like em, some don't.
I think you need to just get on and have fun - not worry about upgrades until you have a problem / more info.
You best bet is to first learn all about a perfect floating set-up from any of the great sites on the net.
Good luck!
« Reply #3 on: June 12, 2006, 11:28:37 PM »
Blue did a thread about the Tremol-no in this very forum. Check it out!
namle
« Reply #4 on: June 13, 2006, 01:04:23 PM »
hmm cool thanks guys
ive learnt the proper way to set everything up already
mine is a float
so far think back and forth only the tremol-no is worth the bucks
not sure though
willl do more research
thanks again
downrodeo
« Reply #5 on: June 14, 2006, 03:46:57 AM »
I didn't really like the D-Tuna. Mine sucked and the spring seemed not to work as it was supposed to. The spring is a very poor feature in my humble opinion. The biggest problem that I had was that it tended not to get me exactly to D. It was usually 1/4 step off or something like that. But, anyway, the Tremol-no looks great for stabilizing that floating trem, adding versatility, tone, etc. I really like the idea. The EVH d-Tuna is just unreliable and tends to disable pulling up on the bar.
Kilby
« Reply #6 on: June 20, 2006, 12:41:43 PM »
My D-Tuna is a huffy little bugger, but does get to D though I did find that it worked best with the Peavey EVH strungs, so it may be a string gauge issue.
Also have a look at the hipshot thingie.
OH yeah, I don't actually use the d-tuna any more as my playing is cr@p enough wothout involving drop D
Rob...
Goodbye London !
