Nailbomb x Warpig x Miracle Man Neck?!
Started by WITH FULL DISTORTION, June 13, 2006, 05:10:34 AM
Hails Guys... what tonal characteristics should i expect from each of these pickusp in the neck spot?
i man, how do you compare them!?
Hails
jp
As far as I know the Miracle Man and the Warpig neck are the same.. same magnet and wind so...
As for the nailbomb, I dunno.
Jonesy
Nailbomb: Mid aggresive and slightly old school metal sounding...
Miracle man: Smoother with a less prominant mids. Tighter and more powerfull lower eq's...
Warpig: Bass heavy with less highs than the other two.
Thats as far as i know
Nailbomb - Mississippi Queen - Mothers milk
Mister Crowley
Quote from: Afghan DaveAs far as I know the Miracle Man and the Warpig neck are the same.. same magnet and wind so...
Sorry that's incorrect. Miracle Man and the Warpig are two totally different pickups. MM has a ceramic magnet and the WarPig has an Alnico V magnet. The Nailbomd also has a Alcio V magnet so you might have confused these two. Jonsey gave a pretty acturate description of each pickup though.
Sorry, Mr Crowley, but we're talking about the neck pups.
The MM neck is Alnico.
When you're right, you're right...
The topic was regarding NECK pickups and I've been knockin' around here for too long.
Thanks Ben.
Mister Crowley
Just going by what this website and Guitar magazines review say.  :roll:
I still don't think the Miracle Man and WarPigs are almost the same pup though.
You would be right if we were talking about BRIDGE pickups. The two are totally different BUT as we are talking NECK PICKUPS
The calibrated sets offer Warpig neck and MM neck that have an almost exactly similar construction & wind.
I'm outta here now.
Best of luck WITH FULL DISTORTION... PDT_038
I´m asking that about the NECK pickups Because someone said that the warpig and miracle man were the same pickup, minus the different Magnet.(again, for the NECK Slot)
so.. Do You Think the Bridge pickups always sound the same in the neck ? i mean, the pickup characteristics.
thats why i´m asking about then...
i ´m figuring out that my fender, has lots of mids.. because i installed the Duncan Custom 5 in my Charvel, and it lacked mids(It Is a scooped middles pickup), and when i installed it on my fender, it revived the mids .
so... if i´m planning to put a BKP pickup in my CHARVEL... It´s better to choose one with MIDS. cause i´m thinking the Charvel lacks mids.
Charvel has 24´75 short scale and floyd rose.
and the Fender is 25,5 scale, 21 frets.. and Vintage Tremolo bridge.
In theory, both have a Basswood body, but the fender has a blurred mapple Cap. and i´m not sure if the Charvel Fusion is Basswood or Poplar.
The Ibanez has Mahogany body, and i just swaped the original cr@p ibanez qm1 and qm2 pickups(ultra shrill and brighty.)
for Two Duncan Designed Hb103(kinda copy of Duncan Distortions)
and it got a thick sound , lack of highs...
those pickups were in my Schecter Avenger. now replaced with 2 emgs (81/85)
i now see that the schecter iw a Bright guitar too. a Middy/high guitar,
i guess it has a basswood body with A Satin Walnut Cap/finish.
i´m happy with the EMGS.
So, i´m also happy with the duncans, but i´ll change the Charvel pups to a bkp combo.
Trilogy neck(100% sure) and maybe a Nailbomb or a Painkiller. in last case.. the Warpig.
Also, the charvel has a good amount of Highs. beautiful highs.
any consideration and tips for these guitars? Ibanez and Charvel(the ones i plan to change pickups)?!!?
Hails and thank´s for the tips
J.P
dasfonzie
Do you post on the SD forums WITH FULL DISTORTION?
Soon we'll be away from here
Step on the gas and wipe that tear away
You are probably right Dasfonzie. Like the sig btw....one sweet dream came true today- ah a man of taste. ( sorry 'bout the hijack- just spotted a fellow traveller)
Quote from: WITH FULL DISTORTIONI´m asking that about the NECK pickups Because someone said that the warpig and miracle man were the same pickup, minus the different Magnet.(again, for the NECK Slot)
J.P
What?!!  :?:  :!:  :!:  :roll:
Quote from: dasfonzieDo you post on the SD forums WITH FULL DISTORTION?
Yeah, with the same username.
Q:)
But im not posting too much recently.
i´m kinda loosing interesting in their pickups
ahahah BEN.. which part of the text you didn´t understand?
The entire text?
AHahAHAHaHAhah
+1 --- I haven't got a scooby what the hell you lot are on about anymore  :?  :?
This thread is starting to bum me out just a bit - no offence intended.
The phrase "Sh1T or get off the pot" springs to mind  :roll:  :roll:
