EVH music man pickup problem?
Started by flyangus, June 17, 2006, 08:19:52 PM
flyangus
Guys,
I just got a second hand MM EVH signature guitar, there's just one thing bothering me - the bridge pickup sounds a little 'single coilish'. I have another MM EVH to compare it to and it's definitely not the same. The pickup selector switch has been changed at some point, could this be it? Any other ideas?
Thanks in advance.
Angus
Davey
if the switch was replaced, it could of accidentaly been wired split  aswell.
flyangus
Thanks, how could I find out? Are there any other faults which could give the same symptom?
Davey
well.. thin and single coily sounding tips it off.
which pickup is it? you can take a look at the wireing inside the control cavity.
each wire is a diferent color and depending on the manufacturer of the pickup, you can check out how it is wired.
flyangus
Thanks. It's the bridge pickup, to start with it was also squealing alot. I cleaned the pot (which was filthy and scratchy) and that appeared to stop the squeals. The selector was changed to a swtichcraft selector, any ideas how it should be wired up so I can check?
Angus
tap the coils with a screw driver while connected to an amp, this way you can find out if only one of the coils is active. If both are active, the wiring could be phase inverted or sth.
I checked the switch on my MM Axis and it looks as if it'd be switching coils independently (for whatever reason).
flyangus
Thanks Hunter,
I just did the check with a screwdriver and both coils seem active, ie. the volume from both 'taps' was the same.
Tim
Sounds like it's been wired in parallel not series.
Tim
fps_dean
Quote from: TimSounds like it's been wired in parallel not series.
This is why you don't let a noob touch your guitar ;)
Which colour wire is connected to where (assuming 4 conductor output)
Colour coding is as per Dimarzio standard codes
Red = hot
Green = earth
Black and white soldered together and taped off - unless coil tap is utilised
Damnit - my next post brings me to 666 posts and I  will be loathe to post anymore as 666 posts looks cool. :twisted:  :evil:  :twisted:
Quote from: FELINEGUITARSDamnit - my next post brings me to 666 posts and I  will be loathe to post anymore as 666 posts looks cool. :twisted:  :evil:  :twisted:
Just be like sambo and post 666 times each day!!
deg0ey
So does that mean we can start a "Feline Smells" thread, and there's nothing you can do about it??
Or would you just give us a good ear bending via PM?  :)
flyangus
Guys, thanks for the replies.
Turns out the pup was open circuit! It must have been working like an ariel to pick up signal? I'm guessing corrosion caused it as there are signs of it elsewhere.
Chris
Is your guitar trans red colour with a floyd?  I just traded one of those in a newcastle shop about three or four weeks ago.  Just wondered whether it might be the same one...
I am actually considering to take out the stock di marzios and replace by a pair of VHIIs. Anyone got an idea whether this could give me more oomph without losing the great cut/crunch of them?
Also a good split sound is quite important, as the Axis is the only "Strat style" guitar I have.
