Pickup installation help
Started by offie, June 21, 2006, 06:03:07 PM
offie
Hi there
Just trying to solder in my Rebel yell into the bridge position on my guitar, but not 100% what to do with the wires nor how to follow the diagram!
I have a 5 way selecter switch and the diagram shows a 3 way one. Sorry I am an absolute nooby!
Do i have to detatch the two wires wrapped in plasticy stuff in order to solder them or not? I am not coil tapping by the way.
Any help would be appreciated! Thanks!
Welcome to the forum- I know someone will come to your aid shortly- come on Phil where are you?
offie
Ooops sorted it by mistake!
Just had a mess around and got it going! Left the covered cables covered and all is working! Woohoo! What a fantastic pickup! THanks tim!!
Offie
Antag
The two wires taped together (green & white IIRC) are for coil-tapping, so you don't have to wire them to anything if you only want the humbucker sound.
As I guess you've figured out :-) the red is the "hot" one, the black & bare wires you solder to a ground point.
