November 22, 2026, 04:42:52 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Guitars, Amps and Effects
Rack Case causing hum
Started by maliciousteve, June 22, 2006, 01:50:33 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
maliciousteve
Guest
Logged
Hey, Everytime i got to screw my power amp back into the rack case i get an annoying hum. When i loosen the screws the hum goes, when i tighten them up, the hum comes back. I've never ever heard of this before, how can i fix this problem? :(
Andy RV
Flyweight
Logged
#1
June 22, 2006, 02:12:02 PM
I've heard that you can get these little rubber pads that you put between the the rack mounting plate and the mounts on the unit, they stop the metal touching, thus stopping the rack case conducting any power from the unit.. or something along those lines.
Check out
http://www.hugeracksinc.com/board/
the are loads of rack nerds over there that will have a easy solution for you.
Middleweight
London & Southeast's Number 1 BKP stockist
Logged
#2
June 22, 2006, 02:49:50 PM
Yeah - they were called humfrees
Small plastic clips that go between the rack ears and the flightcase and isolate the chassis
Also be careful to mak sure power cables and signal cables dont cross or run alongside each other- the signal cable picks up hum fro the mains cable
Print
Go Up
Pages
1
User actions
Forum Ringside
User actions
Print
