Author Topic: Nailbomb first impressions...  (Read 4228 times)
Antag
« on: June 24, 2006, 11:51:10 PM »
Been on a bit of a spending spree lately, in addition to the HD I reviewed earlier, I also got a Nailbomb bridge & VHII neck for my Les Paul :lol: - very fast turn around by the BKP boys on this order - cheers guys! :grin:
After a bit of a struggle I finally got the old pickups out (nevermind solder, that braided wire was damn near welded onto the back of the pot - I nearly cut the blasted thing off before some serious heat & brute force shifted it).
At first, I thought I'd made a mess of the install, next to the Holy Diver in my Korina strat, the Nailbomb had lower output on the clean channel.  Checked everything - wiring, pickup height, volume turned up etc - sure enough it was lower output.  That's not necessarily a bad thing as it has a real nice clean sound - bright & clear.
Then I stepped on the channel switch.
Holy f&<%!#£ sh*^!!! :o :twisted:  :!: - how can such a mild mannered pickup sound so goddam vicious ?!??
I reeled off riff after brutal riff - this thing is made for METAL.  My Les Paul is a really nice one & whenever I pick it up any ideas of subtelty or restraint go out of the window :twisted: - but freed of its cr@ppy Gibson pickups it's even more of a riff machine.  Palm muted downpicking & thrash style riffs have a real "bite" to them with the NB.
To tell the truth, it's not mild mannered at all - 16k is still pretty hot (compared to 16.4 on my HD & 17.8 on my MM) - yet it's quite an achievement by BKP to get a high output bridge humbucker that cleans up so well.
IMO the NB is the most versatile of the 3 BKP bridge humbuckers I've got.  The HD has a thicker, warmer, punchier (louder) clean tone & pushes the valve amp into breaky-up crunch sounds more easily, even though I have it installed in what should be a brighter guitar - I guess that says a lot about how much midrange the HD has, the NB is certainly brighter.
Not sure I really have a preference - the NB, HD & MM are all great pickups.  They're all different but between them cover pretty much all the sounds I like (who wants a load of guitars that all sound exactly the same anyway?). YMMV...
Eric
Re: Nailbomb first impressions...
« Reply #1 on: June 25, 2006, 01:14:04 AM »
Quote from: Antag
LOL
Glad you're digging the NB so much. How is the VH2 neck working out for you? The NB bridge VH2 neck sounds pretty damn cool.
OD-Black_Fire
« Reply #2 on: June 25, 2006, 01:48:07 AM »
How are the NB's harmonics compaired to the HD?
Antag
« Reply #3 on: June 25, 2006, 04:05:09 PM »
The VHII neck seems to balance pretty well, output wise, with the NB bridge.  The tone is a really nice rounded PAF tone, with a bit more output - sort of how I always thought a PAF should sound.  If you wanted to get a classic rock Les Paul tone then judging by this neck pickup you could do a lot worse than a VHII set...
As for the harmonics, both NB & HD have very rich harmonics, but maybe the HD picks them up a little bit better.  However, it's worth noting that I have the two pickups installed in totally different guitars which probably has something to do with it.  If you want something that will help with divebomb/pull up squeals & pinch harmonics, they certainly scream on my HD strat :twisted: but I doubt either pickup would let you down.
Tim
  • BKP
« Reply #4 on: June 25, 2006, 04:21:34 PM »
Good breakdown of the pickups performances in your guitars-always glad to have feedback like this-very constructive!
Tim
deg0ey
« Reply #5 on: June 25, 2006, 04:54:02 PM »
When I read your review of the HD, I pretty much decided I wanted to get one of those for my next guitar - but now I want the nailbomb...grrr damn you!
EDIT:
Quote from: Tim
But very annoying for those of us that have to actually choose one of them, due to a lack of funds
