Gloss finishes on necks and what to do about them!
Started by downrodeo, June 25, 2006, 11:36:32 PM
downrodeo
So, I have this Schecter C-1 Classic. It's neck through and it has a gloss finish...sometimes it's good but a lot of times it can be sticky for faster stuff and improv. I don't mind it a great deal, but it can be annoying...the stickiness of it, I mean. Should I trust my local guitar shop and get  the neck sanded. I hear this should be what I should do about the stickiness, but I'm not sure...
I used some steel wool on my Lp's neck and its been great ever since  :D
downrodeo
Searcher
Yeah, steel wool and lemon oil are common cures for glossy necks.
downrodeo
Even if the neck has a colored finish (mine is a matching amber color) will it look alright? It is a beautiful guitar and I wouldn't want to disfigure it any.
HJM
Mask off the headstock and body joint, then you'll get a nice sharp line between the playing area and the nice glossy back of the body and headstock. The neck will just look matt. It looks alright as long as you rung the wool allong the lenght of the neck and stick to 0000 gauge wool.
jordan
Just last week I took some 000 wire wool to the back of my 50s strat neck, and am very pleased with the result. Make sure you cover the pickups with something (eg. masking tape) to stop any grains of wool getting in them. I ended up putting the body of the guitar in a tescos bag :)
As long as you don't take off too much of the finish, you shouldn't have to treat the neck with anything. Remember, you're aiming to take off the gloss, not the finish. It's a simple job and should take no more than 10 mins.
Good luck.
[url="//www.jordanhumber.co.uk"]www.jordanhumber.co.uk[/url]
[url="http://creationoffrank.blogspot.com"]http://creationoffrank.blogspot.com[/url]
Quote from: downrodeoAre you SERIOUS!? Did it look okay?
Yeah it doesnt look too bad actually, its much better to play now.
downrodeo
Thanks guys, you guys are so much better than the morons on the ESP/LTD forum  :lol: (There's a group of 8 year olds if I've ever seen one...) :roll:
I bought a Mex Tele from a guy I used to know and admittedly I got it ridiculously cheap but the moron had rubbed off the finish to such an extent that he buggered it up totally. I have improved it but it could do with re finishing now- I think he now collects trollies in a supermarket carpark and, with no disrespect to those who perform such a function, I am surprised that he is able to rise to that challenge. Sorry for hijack- rant over.
downrodeo
Do you guys have any tips on how to perform this "minor" operation properly???
I do this on a lot of guitar necks.  Like mentioned above it is a good idea to mask a line at the headstock and heel to keep it looking neat.  I wouldnt use anything coarser than 0000 but youmay get by with 000, if you go any coarser you will regret it.  If you have any problems finding wire wool that fine check out //www.axminster.co.uk, they stock it.
i usually apply a small amount of prepared beeswax (briwax) when rubbing with the wire wool because i feel it leaves it looking more professional.
It shouldnt take much work to get a suitable matt finish but be aware that your hand will re-buff the finish and it will get glossy spots sooner or later and you will have to repeat the process (probably annually depending how often you play), this is true of most matt finshes anyway.
Mask off any electrics to stop wire wool getting near them!
This process is reversable (good if you want to sell the guitar) because you can always rebuff the neck but if you have to do it often and find that the clear coat is getting thin it might be worth getting a few new coats of clear lacquer to make sure you never go through to the colour, although to be honest i think this would take years.
Incedently, on alot of the guitars i make i use an oil and wax finish on the wood which feels much nicer than gloss or matt lacquer
Quote from: WezVMask off any electrics to stop wire wool getting near them!
What are electrics doing on the neck>? :?
when you use wire wool it produces alot of wire dust that floats around and gets attracted to the pup's and electrics, it can cause problems.
Ignore this at you peril :D
CaffeineJunkie
Quote from: WezVIgnore this at you peril :D
hmmm...is that a dare???
