Author Topic: How would you remove the finish off this??  (Read 4594 times)
Andy Lindsay
    • http://www.crimesofpassion.org
« on: July 12, 2006, 10:54:56 PM »
Picked this 7 string hardtail up from the states recently. Not a fan of the 70's George and Mildred curtain colour scheme on it one bit! What's the best way to remove the finish? Burn it off? It's got some more crazy swirl stuff on the headstock too.
« Reply #1 on: July 12, 2006, 10:59:43 PM »
Heat gun works amazingly, just let it melt the paint/lacquer and then scr@pe it off with a cabinet scr@per.
BleedMarshall
« Reply #2 on: July 13, 2006, 12:00:01 AM »
Sandpaper is good, steel wool is good too, but I prefer sanding, and that is handsanding with sandpaper. Start with a low number grit, which will strip the paint quicker, and as the wood is shown, use a higher grit to smooth out the rougher spots from the earlier sanding. This will insure better paint coverage, and minimize sanding later during the paint process. I am in the process of redoing a Jackson "V" for a friend now. Not easy, and time comnsuming, but it is worth it in the long run.
« Reply #3 on: July 13, 2006, 12:54:24 AM »
Disassemble it completely
Heat gun and cabinet scr@per/ chisel if you are feeling brave
Finish with abrasive papers
Searcher
« Reply #4 on: July 13, 2006, 03:23:42 AM »
Note: burning it off and using a heat gun aren't the same.   :wink:
Quote from: Sifu Ben
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #5 on: July 13, 2006, 04:44:12 AM »
Or sell it and buy another one, swirl finishes are pretty collectable.
I see a rainbow rising
Look there on the horizon
And I'm coming home
« Reply #6 on: July 13, 2006, 11:25:43 AM »
Looks like someone barfed on it after too much beer and curry and then stirred through it with his hands.
Plug in that hot air gun!
Chris
« Reply #7 on: July 13, 2006, 12:28:29 PM »
I normally use a chemical paint stripper like NitroMors to get the bulk of the finish off.  I find it does a better job of nooks and crevices than i've been able to get with sandpaper.  Never tried a heatgun...
Just another option...
« Reply #8 on: July 13, 2006, 12:40:43 PM »
Quote from: gingataff
Malicious Steve has a trem version for sale in Seconds out if you sell this one
Crazy_Joe
« Reply #9 on: July 13, 2006, 01:40:50 PM »
I love that finish, what is wrong with it?
Black Dogs
« Reply #10 on: July 13, 2006, 01:41:23 PM »
Quote from: Crazy_Joe
Everything  :?  :P
