Hello Wez,
I have my humbuckers wired out of phase with each other when the switch is activated. That way each pickup sounds completely 'stock' when used on it's own, and in the middle toggle position they blend in the normal way. It's only the combination of middle toggle and tone pot pulled up that activates the 'Greeny' sound. Apparently Snowy White has had his Goldtop done this way too.
I then find that the degree of the effect is adjusted by turning down one of the volume controls; hence giving it's phase opposite pickup more or less opposition. The reason I then lowered the bridge pickup just 1mm lower than the neck p/u was to achieve my favourite balance with both volumes on 10. The added bonus was that the treble p/u became even sweeter sounding even when used alone. To be exact a gap ( between fretted string and top of polepiece) of 3mm bridge, 2mm neck.
I attach the wiring diagram for the DPDT switch so you can see what I may not have explained very well. The braiding still goes to the back of the pot(s) and thus to earth, the white and green remain joined just as they left the factory- leaving the black and red hot/cold wires to go to the middle two posts of the switch. The diagram makes the rest obvious.
As the switch stands vertical, the mids connect to the bottom row when pressed down. I therefore put both 'hot' connections from pickup on the middle pin and out to the volume pot on the lower pin on the right hand side as viewed in the drawing. Thus when the switch is pulled up, the earthing remains intact elsewhere, but the red/black 'swap places' on one pickup only.
Oh, and finally (without wishing to sound patronising folks):
Remember the Arched top type Les Paul requires a 3/8" length shaft to reach the top of the body, whereas others such as the flat topped
S.Gs and Les Paul Studios etc. require only the oridinary 3/16" shaft length.
I hope this helps.
Regards,
Derek.
:D
