would it be possible....
Started by CaffeineJunkie, July 19, 2006, 01:35:01 PM
CaffeineJunkie
hi,
just been thinking about how to get a true single coil tone out of a humbucker fitted guitar without re-routing anything....
would it be possible to mount two singlecoils next to each other and have them 'buck' - but still change to singlecoils when i flick a switch?????
Cheers
CJ
n_mountain
Quotewould it be possible to mount two singlecoils next to each other and have them 'buck' - but still change to singlecoils when i flick a switch?????
It is possible but as far as I understand it will change the sound of the single coils (in sc mode) as one sc will sense the magnet of the other sc being so close. This is not necessarily bad , just different and maybe a little unpredictable.
Please, anyone correct me if that is not the case :)
You could always get a Missisipi Queen which is basically a single coil in a Humbucker cover.
CaffeineJunkie
yeh but i already got a MQ and am lookin for somethin different
wouldnt having the other magnet so close create a shedload of feedback all the time?
n_mountain
feedback??
hmm ?? I don't think so...
...after all a humbucker has two magnets close to each other and that's no problem.
Or have a look at the Steve Morse guitar:
http://www.musik-schmidt.de/osc-schmidt/catalog/images/MUSIC-MAN_Steve-Morse-Blueburst_1.jpg
He doesn't seem to have a problem...
CaffeineJunkie
i thought a HB had one big magnet at the bottom, which is why it sounded different to SCs when split???
n_mountain
:oops:
ahem yeah you're right, the humbucker has only one magnet  :oops:  :oops:  :oops:
But still Steve Morse doesn't seem to have a problem  :D :oops:
CaffeineJunkie
i take it you are referring to the 2 middle pups??? if so then they are about an inch apart, whereas i was thinking of 2 singles in a HB slot....
just a thought :P
blue
i think Tim has done a pickup like this, the Knuckleduster, which i believe is exclusively for Nathan Sheppard guitars.  also Swineshead do a humbucker which is two actual single coil pickups together, although i've no idea what it sounds like.
maybe Tim would do something like this, i'd be interested.
CaffeineJunkie
Quote from: bluei think Tim has done a pickup like this, the Knuckleduster, which i believe is exclusively for Nathan Sheppard guitars.  also Swineshead do a humbucker which is two actual single coil pickups together, although i've no idea what it sounds like.
kool name .. ne idea what it sounds like??
n_mountain
the back sc is really close to the HB, that's what I was refereing to. More or less as close as your two sc would be.
I don't know if the effect is the same, though.
CaffeineJunkie
n_mountain
Just went to the Nathan Sheppard site.
Wow!!
Nice guitars and the one with the knuckleduster looks sweet :)
Davey
you could always do the Vai approach...
put a SC in there and a dummy coil next to it.
he does that with his sustainer equipped guitars
CaffeineJunkie
Quote from: Daveyyou could always do the Vai approach...
spose, but that don't sound as kool as having a 'Bare Knuckle Knuckleduster'
Davey
Quote from: CaffeineJunkie
very true
