Author Topic: Apaches  (Read 6669 times)
Apaches
« on: June 05, 2005, 06:15:26 PM »
Well I have just collected my 1970's Strat from Ron at R/2e Guitars. He has installed Apaches and we decided on a push/pull pot mod that means the neck pup can be used with both the bridge & bridge middle. If anyone out there is dithering about getting installing Apaches then dont- just do it and I promise you will not regret it. They also have plenty of punch too. Dial a bit of gain in and they will reward with an "alive" sound. The neck is just stunning- that lovely "plummy" tone. Even Mrs 38th, when coerced into a blind test against my stock 1960's reissue, said that the BKPs sounded much better ( ok, she was trying to shut me up to get me to do some domestic chore or other I admit but she admitted later that "bareknuckling" my other Strat is indeed on the agenda when funds permit).Cheers to all at BKP and, of course, Ron who I will be seeing again as soon as I can. I will also have to consider what to get for my Tele
R/2e
    • http://www.ron2e.com
Apaches
« Reply #1 on: June 05, 2005, 08:53:38 PM »
Amen brother, you have seen the righteous light!! Apache's rule!
Very interesting neck and bridge mix on 38th's Strat, quite different to the other two in-between sounds, very usable. A worthwhile mod, just a push/pull switch to bring in the neck pickup in any position of the 5 way, so effectively two additional sounds, neck and bridge, and all three together.
Tim
  • BKP
Apaches
« Reply #2 on: June 05, 2005, 09:33:04 PM »
Great 38th, a good result.Apaches are one of my fav single coil sets we make and I must admit I still have the original, final, prototype set in my Relic-they're not coming out for anything!
Tim
